Camshaft LSA? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2004, 07:12 PM
Camshaft LSA?
The Lobe Seperation.....whats the difference?? 106, 110 114????
Old 03-15-2004, 07:19 PM
woodz428's Avatar
Troll Hunter
Arrow
In simple terms, the wider the lobe separation the better bottom end and idle you have. The narrower works the opposite. For most street driven cars I think 110 is about as low as you really want. Don't compare modern cam specs with old specs, for many years everyone used their own point of measurement until the standard(now) of .050 was used.
Old 03-15-2004, 07:55 PM
So....... 114 is torkier than a 110.
Old 03-15-2004, 09:04 PM
Steve karch's Avatar
I don't think it will be noticeably torquier but it will have a smoother idle and high vacuum at idle. OEM's spec wide lsa's for smoother idle.
Old 03-15-2004, 09:31 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Your lower number LSA cams will tend to be peakier in the power band, but will make more power in the "sweat spot". The higher number LSA cams will have a flatter power band with the better idle as mentioned. FWIW most all of your large race cams use a tighter LSA(smaller number, usually 106). If forced induction or nitrous are in the plan you want to keep away from the 106 range cams.
Chris
