camshaft power or not - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2010, 08:29 PM
: changing from 402 lift cam to 450 cam on 350/.060 will this be a drastick change in take off when you are already @ 2200 rpm and punch the pedel;this is for dirt track
Old 06-15-2010, 10:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Given the increased duration that the extra lift requires, there will be an increase in power at a higher RPM, all else being equal. And before you ask, I do not know how much difference.
AFA "drastic", no, there won't be a drastic difference. In fact, if you're racing on dirt, it may give traction problems where there were none before- and will actually accelerate slower. It all depends on a LOT of variables.
Old 06-15-2010, 10:42 PM
techinspector1's Avatar
Wiki Edits: 326
If you're lugging the motor down to 2200 in the corners, you need more gear before you need more cam.
Camshaft Break In beertracker Engine 2 05-25-2010 07:13 PM
Right cam for a 383? atomicrockerdude Engine 22 11-02-2009 12:13 AM
Help with camshaft... i'm lost on what anything means elcrusch1 Engine 10 10-02-2006 09:33 AM
Advise on Porta Power choice meanroy Body - Exterior 7 06-23-2004 11:38 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
