Originally Posted by crussell85
Why is the brodix -8 PRO heads a bad choice of heads. I did a fair amount of research before I purchased these heads. The have 2.02 intake and 1.60 exhaust, 185 cc intake runner and 67cc combustion chamber.
In your 1st post your intended use is Towing, Offroading & everyday use.
This requires lots of Torque at lower engine speeds.
The Brodix -8Pro heads make power in the mid to upper rpm range
Cubic Inch--Compression------Camshaft------------ RPM-------Application
355-406---- 9.1 Minimum--Hydraulic/Flat Tappet- 3500-6500----Street/Pro Street
From Brodix's site>>
http://www.brodix.com/heads/-8.html
This Info may be using the larger 2.08"/1.60" valves so you could be Ok with the smaller valves. Check with Brodix & see what they say.
