Camshaft question ? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-10-2008, 12:49 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
"native languish"
And you used the spell checker for this???????
  #17 (permalink)
Old 09-10-2008, 08:46 AM
With 236/242 degrees at 0.050", the max lift should be around 0.485" on the intake 0.500" on the exhaust with an advertise duration of around 286/292.
If you find a cam with 230 to 236 degrees on the intake and another 6 to 10 degrees on the exhaust, then that would be good enough. But use a narrow LSA, from 105 to 107.
Advertised duration should be around 50 degrees more than the at 0.050" duration. Any less and the engine will make less power than it should and any more it risks a lobe failure. (IMHO)
Use a ZDDP additive to keep your new cam from going flat.
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
383 stroker 73monte Engine 10 12-05-2009 08:02 PM
camshaft breakin question? runn141 Engine 11 02-07-2008 02:36 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
