camshaft question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2010, 05:09 PM
The mobile view is crap
camshaft question
I am rebuilding a chevy 350 out of a 1993 K1500. The cylinder heads are the 193's I believe they are called Swirl Port Heads but correct me if I am wrong. I am curious about the camshaft. The machine shop sold me a stock camshaft and he told me that is all he would sell me due to computer problems with the tbi. I am curious if I can bump up the cam a little without any problems and if I can what cam. I am not looking for anything wild. I am looking for something that I can haul my 3500 lb camper with and not have to many problems with it. I want something with decent mileage but I don't need something that will roast the tires all day long or something that will do a quarter mile in two seconds. I am just curious about bumping up the cam to benefit myself and maybe compliment the rest of the engine a little better, or should I just stay with the stock cam. The stock cam according to my Hayes manuel is .2565 intake and .2690 exhaust. Rear gears are 3.73 with 33" tires. Thank you
Old 06-05-2010, 05:17 PM
BOBCRMAN@aol.com's Avatar
You can go to what everybody markets as an "RV" cam and have no problems with electronics. Better gas mileage and pulling power.. I usually spec one on my "stock pickup truck" rebuilds. Along with better timing set and M55A oil pump.
Old 06-05-2010, 06:23 PM
so what would be classed as an "RV" cam?
Old 06-05-2010, 07:53 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
here is one that is specificly made for you engine, and although i dont like comp very much this doesn't seem like a bad cam at all and all their other 87-98' 305-350 hyd roller TBI cams mentioned having the computer modified but this one didn't so i would say that this one should be able to just about go right in without any hasle
http://www.competitionproducts.com/C...o/CCA08-501-8/
here is one from crane but it wont be too much better than the stock one, but it would help a little, and you could probably get away with putting 1.6 rockers on it since the lift is so low to raise up the lift at the valve a bit, in my opinion this cam would need that.
http://cranecams.com/pdf/Page134.pdf
these are just a couple that i found in a few minutes of looking, the problem is that not that many cam companies make computer compatible cams that you wont have to reflash the computer for, these two claim to be able to be used with the stock flashing on the computer.
Old 06-05-2010, 08:10 PM
how about something like this. http://www.summitracing.com/parts/EDL-3702/
Old 06-05-2010, 08:33 PM
my87Z's Avatar
that is a hydraulic flat tappet cam, you need a hydraulic roller cam, beacuse in 93' no engine chevy produced still used a flat-tappet cam they were all rollers. i know that a roller cost a bit more but it would be just plan stupid to go to a flat tappet to a roller especially with the low content of zinc and phosferous that engine oils today have in them. besides with the engine you have now you likely wouldn't have to change your roller lifter if you just changed the roller cam as these are hardley ever worn out. but if you change to a f/t cam you will have to not only by the cam but the lifters as well.
Old 06-05-2010, 09:30 PM
I don't understand the last post because the engine had a hydraulic flat tappet cam in it and does not even have the provisions to be a roller block. It does not have the holes for the cam plate or the bosses for the spider for the lifters. My cousin rebuilt the engine in his 95 K1500 and it had the provisions to be a roller block but it ran a flat tappet cam. I also have a sbc 383 that is a block out of a 95 K1500 that ran a flat tappet cam but has the provisions to be a roller block and now it has a hydraulic roller cam installed in it. If the block had the provisions to be a roller block I would run a roller cam because I have a pile of 4.3 liters sitting around that I could rob the lifters out of.
Old 06-05-2010, 10:02 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Not ALL blocks '87-up are provisioned for a roller, I have a c/n 10054727 block that is like yours, there are also 14079287, 14088548, and 14101148 that don't have the provisions.
Be careful what you do, cam-wise. The vacuum is a big part of what the ECM uses to determine how to "tune" the engine, so don't go overboard.
I'd suggest you check out the Chevy-specific boards for TBI engines, they go into this a lot. Like www.thirdgen.org, www.nastyz28.com, www.tbichips.com, etc.
Good luck.
Old 06-05-2010, 11:09 PM
my87Z's Avatar
well dag-on, sorry about that, i knew that chevy started making the roller blocks in 87' and i knew that they still used flat tappet cams for a few years but i didin't think they were still using them in 93'. but i did think that all the blocks after 87' had the provisions for the roller. again sorry about that. well i did look at the cam that you listed and it doesn't look too agressive. would you be willing to have the computer reprogramed, if so this would make you options a hole lot easier
Old 06-06-2010, 06:26 PM
the computer programming is plausible, I just want something that is going to give me more grunt and maybe a little more mileage. This is a daily driver and nothing else. More of a recreational vehicle driven on the weekends and towing in the summer. Is the stock cam bad? Is there a different cam that could be used and be happier all around with it, or is the stock cam the best over all option?
Old 06-06-2010, 06:40 PM
my87Z's Avatar
this is just my opinion but anytime i have ever and in the future will ever rebuild and engine, i'm going to do it better than chevy did from the factory, especially with the 70's-90's engines. i just can deal with 180hp anymore, acutally i never could. i would see about having some minor work done to the heads, or using the top end off a 96-00' 5.7 vortec engine. i would use a little better than stock cam (as much i could get away with under my budget without having to change too much of the rest of the drivetrain) my goal with you enigne would be to geat atleast 275-300hp/335-360tq, this should still get decent gas mileage and still be very easy to drive on the street, and be great for towing a trailer around
Old 06-06-2010, 06:48 PM
the heads are staying for sure. so with the stock heads and an edelbrock performer multipoint conversion intake what would be the cam of choice, no holds barred here guys, I am looking for suggestions on a cam, Sorry I forgot to mention earlier that the engine in the truck is setup with the Edlebrock Multipoint conversion, so it already has a custom chip in it to make the multipoint function correctly, So it wouldn't be a big thing to get a new chip for it.
Old 06-06-2010, 07:51 PM
my87Z's Avatar
http://www.summitracing.com/parts/CCA-12-388-4/
http://www.summitracing.com/parts/CCA-12-249-4/
again i dont like comp all that much but that is just a personal preference, but the original cam you cam up with i think was too close to a stock cam and i dont think you really would have been happy with the outcome of it, so these two cams give you a tad more duration and lift, but they dont have too much duration that it would require you to change valve springs, stall, and gears. i think you would end up being very happy with these cams
Old 06-06-2010, 08:26 PM
If Old Bogie or TechInspector would have any insight on this it would be nice. I know it is the average guy looking for a camshaft for a perfect engine. I talked to tech about this in another post of mine and after talking to him I bought a few books and have read a lot of stuff on camshafts but I am still lost when it comes to selecting a cam.
Old 06-07-2010, 04:55 AM
techinspector1's Avatar
Wiki Edits: 326
First thing I would want to know is.....what's the cam timing that's in it now?
383 stroker 73monte Engine 13 05-11-2016 12:17 PM
supercharger.... 73monte Engine 16 07-24-2010 11:27 AM
camshaft breakin question? runn141 Engine 11 02-07-2008 03:36 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 02:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 11:25 AM
