Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Camshaft Question
Old 10-03-2006, 06:10 PM
curtis73's Avatar
curtis73 curtis73 is offline
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Less duration shifts the torque peak to a lower RPM. Lift can have varying effects, but its basically based on the heads. Heads will flow better at higher lifts up to a certain point. Above that lift they will start flowing less. Many stock heads improve their lift up to about .4 or .5 inches. Adding more lift by swapping to higher ratio rockers can shift the torque peak up a little in the RPMs because it has the effect of adding a tiny bit of duration. Duration measured at .050 lift translates to more lift faster at the valve itself. Its usually a tiny distinction. If you want your torque to peak at 2000 rpms and you switch to higher ratio rockers, it might now peak at 2075 or something.
So in a nutshell, use the duration and head flow to determine where the torque will peak, then to maximize the power curves, select a lift that takes advantage of what the head has to offer and no more. If your head starts dropping flow above .5" lift, then chose a combo that won't take you over .5" lift.
