camshafts - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2006, 11:34 PM
camshafts
are hydraulic flat tappet cams more inclined to wipe out a lobe than a solid flat tappet camshaft. my reasoning here is that hyd grinds have 0 lash and a certain amout of preload vs. a solid profile has lash specs. just a thought, any opinions? Turbo
Old 02-10-2006, 01:08 AM
GoneNova/406's Avatar
you adj. the hyd. at 0 lash and providing that you adj. it right and have the right springs it shouldn't happen on either one unless you adj. them too tight.also with hyd.'s you can have fast bleed lifters which give you even more room for error unless there on a huge cam.some cams like wolverine blue racer,have fast bleeds for all their cams.not sure how they do it since crane bought them out.i got one right before they changed the packaging and they still did it.so the answer is if you over tighten either one of them they will both do it
Old 02-10-2006, 09:10 AM
The wear doesn't occur on the heel of the cam, it happens on the lobe, where both types of lifters are under increased stress. The hydraulic lifter bleeds down a little each stroke and glides over the heel as it refills with oil.
Old 02-10-2006, 12:29 PM
sbchevfreak's Avatar
Licenced Automotive Technician
On a solid cam, the lash specs are there for thermal expansion/valve, seat, & lifter wear. A solid ground cam has clearance ramps to take up this extra clearance, as well as adjusters on the rockers. A flat tappet hydraulic does not. Thermal expansion & wear are compensated by the action of the hydraulic lifter.
Camshafts, EastCoastSBC Engine 10 01-08-2006 03:02 PM
EFI camshafts shagginwagonvic Engine 5 02-13-2005 07:45 AM
What is involved in Changing Camshafts? rick458 Engine 12 01-27-2005 07:56 PM
Small base circle camshafts?? Mightymouse Engine 3 08-03-2004 10:01 AM
Opinions on PAW camshafts! CrazyT Engine 6 01-17-2003 09:43 AM
