camshafts - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2006, 11:49 PM
camshafts
are hydraulic flat tappet cams more inclined to wipe out a lobe than a solid flat tappet camshaft. my reasoning here is that hyd grinds have 0 lash and a certain amout of preload vs. a solid profile has lash specs. just a thought, any opinions? Turbo
Old 02-10-2006, 12:39 AM
BOBCRMAN@aol.com's Avatar
Actually hydraulic cams are easier on lobes because of less spring tension and zero lash. Mis adjusted solids tend to strike the cam as the clearance ramp starts.
TECH BULLETIN: Flat Tappet Camshafts 71C10 Engine 5 12-06-2005 07:27 PM
comparison of two camshafts vpoirier Engine 5 11-28-2004 11:18 AM
Small base circle camshafts?? Mightymouse Engine 3 08-03-2004 10:01 AM
camshafts....... pull the motor? Thacolbster Engine 3 01-27-2003 01:47 AM
Opinions on PAW camshafts! CrazyT Engine 6 01-17-2003 09:43 AM
