Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - camshafts for sbc (302,305,307,327)
  #16 (permalink)
Old 03-21-2012, 09:58 PM
Dannyringo Dannyringo is offline
Originally Posted by blackpanther68
so all of tht stuff f88 firebird mentioned wouldnt b good 4 a daily driver? so far now the parts i do have are aluminum dual plane intake, the quadrajet 750, (friday) the 305ho heads. .
so the things i dont have yet are just the cam 4 real 4real. . the nova has a powerglide tranny 4 now but maybe a 700r4 joint in the future and the type of rear end where 1 tire pulls.
im just looking to get "Black Panther" 2 the point where she stops gettin whooped up on the street when someone tests me. and still be able to put 3 gallons in and drive where i want 2.
o yeah and my family is jii seasoned race car heads. my dad maybe knows how 2 do something with the heads. instead of gwappin it out at a machine shop. if tht means anything. cuz i would like compression up a bit. if the 305'z wont do it
Now if you listen closely and do your homework, you'll find out I am right with my information...If you go with the 750 carb, your going to loose low end TQ. Whereas, if you look at dyno results, it will be hard to beat a Quick Fuel 600cfm carb...Why, because unless your buying a new HP holley 750 carb, I can guarantee you, you'll have a bog when you mash the pedal to the metal. You'll get frustrated trying to figure out why and will finally sell it...One the other hand a 600 cfm quick fuel will give you the seat of the pants rocket lauch your looking for in a street machine. The 750cfm would be great if it was going to be built to haul above 6,000 rpm...But I do not think your going to do that that often...Most will be street light to street light and low end TQ is where it is at...The 600cfm will give high velocity to the heads and cam your intending to use...The 750 will fall on it's face off the line..I have seen this first hand when I was young....
P.S. I just saw that your going to use the Q-jet....THat is going to be a very good carb to go for it~!
