Can a 1994 4l60e work behind a carburated engine
i have an obd1 4l60e with the harness and the computer and am asking what it might take to run it behind a carbed v8. Which sensors would need to be put on? Or can i bypass the sensors with a specific resistance value to trick the computer into thinking the engine is running right. just a thought any input helps thanx charlie
reply
What i'm doing is a v8 into a 94 s10 blazer frame and I have all the stock blazer parts so from what you are saying I need to put the 4.3l map sensor and tps sensor onto the v8 correct? or do i need a 5.7l map sensor?
Quite probably you will need the Mass air flow sensor,if it runs one. I believe engine load is calculated by that and also shift points as well.
no maf it is a central port injected vortec 4.3
| swapped engine, now 4l60e trans wont work. | heavyfooted | Transmission - Rearend | 0 | 05-22-2010 05:32 PM |
| 1994 chevy g10 4.3 v6 van 4l60e question | kracker | Transmission - Rearend | 2 | 10-25-2009 08:35 AM |
| 1994 4L60E Problem | Redneck8686 | Transmission - Rearend | 8 | 07-24-2009 05:21 AM |
| 4l60e 1994 Gmc 1500 | AMp.Wolf | Transmission - Rearend | 19 | 04-25-2009 03:24 AM |
| 4l60, Or 4l60e 1994 Gmc 4wd | buddy powell | Transmission - Rearend | 4 | 10-14-2004 06:16 AM |
