Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Can a 1999 4l60e case be used for 2002 with bad case lugs
Old 02-26-2012, 06:20 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by misterchevy
2002 case with bad lugs. Have a 1999 case center section can it be used with 02 valve body, plate, and gaskets, harness and all the rest of the 02 parts.
GM made changes in the valve body in 2001 in the area of the TCC regulator passages, gaskets, separator plate. i would suggest use of the 1999 v-body , separator plate and matching gaskets for the 1999 case
