-   -   Can a 1999 4l60e case be used for 2002 with bad case lugs (http://www.hotrodders.com/forum/can-1999-4l60e-case-used-2002-bad-case-lugs-215408.html)
misterchevy 02-25-2012 07:22 PM
2002 case with bad lugs. Have a 1999 case center section can it be used with 02 valve body, plate, and gaskets, harness and all the rest of the 02 parts.
mmerlinn 02-26-2012 01:27 AM
If the case casting numbers match, no problem. Otherwise, maybe.
Crosley 02-26-2012 06:20 AM
GM made changes in the valve body in 2001 in the area of the TCC regulator passages, gaskets, separator plate. i would suggest use of the 1999 v-body , separator plate and matching gaskets for the 1999 case
ethn_bert 02-26-2012 06:20 AM
Nope...2001 GM changed the TCC casting. If you had the VB and Spacer plate you would be good to go.
