Can a 1999 4l60e case be used for 2002 with bad case lugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2012, 07:22 PM
2002 case with bad lugs. Have a 1999 case center section can it be used with 02 valve body, plate, and gaskets, harness and all the rest of the 02 parts.
Old 02-26-2012, 01:27 AM
Wiki Edits: 85
If the case casting numbers match, no problem. Otherwise, maybe.
Old 02-26-2012, 06:20 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
GM made changes in the valve body in 2001 in the area of the TCC regulator passages, gaskets, separator plate. i would suggest use of the 1999 v-body , separator plate and matching gaskets for the 1999 case
Last journal entry: Some More Roll Cage Fabrication
Nope...2001 GM changed the TCC casting. If you had the VB and Spacer plate you would be good to go.
th 250 case, same as 350 Icelander Transmission - Rearend 10 02-03-2009 09:26 PM
t-case capn_crunch4x4 Transmission - Rearend 2 06-02-2006 01:54 PM
T10 Case or SuperT10 case?? GMBrutus Transmission - Rearend 1 02-16-2004 01:37 PM
1999 Chevy Silverado Transfer Case/Transmission? officialfoxracer21 Transmission - Rearend 2 12-15-2002 04:56 PM
