Can "aluminized" tubing be welded? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2007, 09:36 PM
cboy's Avatar
Last journal entry: Finished
Can this tubing from Summit be welded? http://store.summitracing.com/partde...5&autoview=sku
As best I can make out, it is an aluminum coating which is applied to the steel tubing. Could it be welded "as it" or can this coating be easily sanded off for proper welding.
I can get the tubing I want elsewhere, but I'm putting in an order at Summit anyhow so I could save the shipping cost by getting this in my Summit order.
Always learning...and sharing what I've learned.
Old 11-05-2007, 10:22 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
cboy,
I have used the 2.5 aluminized exhaust pipe from Summit. I just ground the are that needed to be welded. Worked fine.
Old 11-05-2007, 11:38 PM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
just sand off the aluminized with some 80 grit and go to town
ive welded straight through it before too though .... it melts right away
Old 11-06-2007, 03:43 AM
Marcel
Last journal entry: Choo-choo town
welding aluminzed tubing
After you welded it, can you coat it with something to return the aluminumization to the joint ?
Old 11-06-2007, 03:48 AM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
If you're just looking for rust protection, I've used rattle can Zink coating. I picked mine up at Lowes.
Old 11-06-2007, 04:31 AM
You should be able to weld any metal you can stick a magnet too. (After cleaning it off.)
Old 11-06-2007, 05:57 AM
powerrodsmike's Avatar
Wiki Edits: 161
At the muffler shop next door the guys just weld through it. It welds just like bare steel. I wouldn't grind it, as that would make a wider area of bare steel for rust to start.
Later, mikey
BE different....ACT normal.
Old 11-06-2007, 07:41 AM
cboy's Avatar
Thanks for the info guys. Makes me a happy camper.
Old 11-06-2007, 06:53 PM
Vortech 4.3's Avatar
jack of all trades
exactly. there isn't enough aluminum there to cause any problems.
i paint my exhaust pipes with BBQ grill paint. works good, for the most part (not a daily driver)
Old 11-06-2007, 07:53 PM
302 Z28's Avatar
Muffler shops just weld right through it then spray some cold galvanizing compound on the joint to keep it from rusting.
Vince
Making dies and rollers to bend square tubing cboy Garage - Tools 20 11-05-2012 05:59 PM
How To: Tubing Bender Twisted Minis Garage - Tools 65 11-18-2008 04:09 PM
Steel tubing for frame and other questions TheBasementHotRod General Rodding Tech 4 11-29-2005 05:51 AM
Scored me SS tubing 302 Z28 Suspension - Brakes - Steering 8 08-29-2005 03:12 PM
Exhaust tubing expanders ease of use. 70bird Engine 4 03-24-2005 03:48 PM
