can any gurus explain "roller" - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-25-2010, 01:05 PM
Originally Posted by v8mazda
ya 1 piece rear main.
roller cam is one of the best to run, though i dont bc i cant aford one so i run the good ole hydrolic tappet!
  #17 (permalink)
Old 04-25-2010, 02:16 PM
havin fun
well ya since you mentioned it now i'm just reading and trying to research on a good build using these vortec. bogie kinda scared me with what he said as far as my original thoughts were. i just wanted a mean motor over 400hp so now looking for builds that will be safe and last me a while unless i'm just missing something or being to paranoid. i still have'nt spent the money on the valve train.... its burning a hole in my pocket though waiting for me to decide lol i'm ready to go i just want to make sure i buy the right set up.
  #18 (permalink)
Old 04-25-2010, 04:00 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
i just reread boogie's post and yes he is right, you certainly need a professional to do your port work, and not just any old machinest is a professional at porting, to be honest i dont think i would have the heads ported i would just look into the guides, valve seats and the bowl some, this is all you really need to do. with the vortecs you would be bettre off staying with a 1.250" spring but you can find these rated for up to around .550" lift you really don need to go with a 1.460" single or dual spring to get what you're looking for. with the machine work i mentioned before i would probably have the heads cut for 2.02/1.60 valve, i would go with a roller cam, probably a dual pattern or you could go with a larger ratio rocker on the exhuast side if you end up going with a single pattern cam. with a decent aftermarket or even stock GM cast crank some decent aftermarket rods and a set of speed pro or keith black hyper pistons keep your compression around 9.5:1 and a cam that wont turn the motor past 6000-6200rpm i think you should be right about were you want to be
  #19 (permalink)
Old 04-25-2010, 04:12 PM
havin fun
good info, thanks. i think i'll just tell the summit rep what i'm looking for and see what he comes up with. and maybe post on here so you guys can chime in.
please explain idle HG and fuel suspension GMR Engine 3 03-07-2009 11:04 AM
Can someone please explain the correct procedure for masking? northiam Body - Exterior 2 11-20-2007 12:35 AM
explain this suspension cboy Suspension - Brakes - Steering 29 02-09-2007 07:50 PM
Question for Edelbrock Guru's wickster Engine 22 07-26-2006 09:57 PM
Some one please Explain the differance? 67 Deuce 4 Me Transmission - Rearend 6 03-28-2005 08:14 PM
