can any one tell me the specs for a 95 chevy 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2011, 05:25 PM
i am buying a 1995 chevy k1500 with a 350 can any one tell me the specs for it?
Old 10-10-2011, 09:06 AM
200-210hp 300 lb/ft torque.
Here is some more specs
Applications
1987-95 trucks and vans (TBI)
Specifications
Block: 1986-Up 4-bolt main (8600lb GVW), 1-piece crankshaft seal (no mechanical fuel pump provision)
Connecting rods: powdered metal
Pistons: dished hypereutectic
Compression ratio: 8.75:1
Oil pump: high-volume
Timing chain: Morse link-type
Camshaft: flat tappet hydraulic (.382''/.402'' lift, 165.9/174.8 at .050'' duration, and 111.9 lobe separation angle)
Cylinder heads: 76cc chamber, 1.94''/1.50'' valves, swirl port intake, center bolt valve cover, and 7-bolt exhaust flange. These are not performance heads. They are high-swirl intended for good low end torque and fuel economy. The intake runner is restrictive because it has a ramp cast into the bottom of the bowl.
Rated at 190 horsepower, 300 ft/lbs TQ when used with OE induction components
The 1996-1999 CSFI Vortec 350's have 255hp@4600rpm 330 lb/ft torque@2800rpm and about an extra 80-100miles out of each tank when compared to thge 88-1995 TBI 350's.
peace
Hog
Old 05-10-2013, 06:08 AM
Chevy 350 is most known V8 engine by General Motors from 1968. I had found complete overview of Chevy engine from Hiperformer site where they have illustrated complete description with some technical information in there page @ Chevy 350 Engine History.
302 Chevy Specs chopurchik Engine 87 01-11-2011 09:40 PM
292 Chevy Specs rookiebuilder Engine 2 09-17-2009 10:10 AM
Chevy 5.3L Specs???? American Muscle Engine 2 04-21-2009 09:42 PM
261 chevy specs kwhp1966 Engine 6 12-03-2005 10:07 AM
sb chevy ign specs Stangpwr71 Engine 3 12-21-2002 12:45 PM
