can any of you help me identify these main bearings sbc 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2013, 09:47 AM
Can anyone help me identify them so I can get a proper replacement
Name:	main bearings.jpg
Old 06-21-2013, 05:48 PM
BOBCRMAN@aol.com's Avatar
Stock GM factory assembled bearing A-200 is the old Delco-Morraine bearing material. No over or undersize stated. Std size.. Clevite, Mahle, ACL, use rod bearing no 663 and.... my brain just went dead ...909 main bearings. P-series is tri-metal. A-is an aluminum type bearing. H-or HN is a race bearing.
Old 06-21-2013, 07:52 PM
thank you
Old 06-21-2013, 09:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The factory often used various incrementally under- and oversize bearings selected to fit a production line crank.
You will note the bearing on the right is 5 tenths (0.0005") oversize.
GM SBC main bearings different seizes by OEM monette999 Engine 10 10-17-2010 08:21 AM
What rod bearings do i have GM SBC 350 monette999 Engine 8 10-16-2010 02:12 PM
SBC 350 bearings recomendation aldfaa Engine 1 09-19-2010 09:44 AM
Are these the correct bearings?? (main bearings) LandonL Engine 3 08-29-2010 07:46 AM
400 sbc wiping out main bearings race140 Engine 8 08-16-2007 12:53 PM
