Can anybody guess what my horsepower might be?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2004, 03:55 PM
Robbie's Avatar
Last journal entry: nova
I have a 72nova with a sb350
my heads are 64cc with the 2.02 / 1.60 vaules with 1.5rollers rockers , with hedman headers
my pistons are flat tops with 4 eyes
im running a tunnelram with 2 450 cfm carbs.. ( rpm-2800-8000)
my cam is a hyd roller 288/286 230/230 560/560 lobe110
(2500-6000 rpm )
trans is a 350 with a 3500 stall
msd dist (#8360)
265-50r15 tires on back.
411 gears
and if someone could give me a tire size thats taller that would bring my ratio down alittle. i wanted to run a 373 but all ready had the 411. any help would be great thanks Robbie
Old 02-08-2004, 04:02 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Id guess 375-400 depending on what brand head you have it may be a little higher.
Any taller tire will help with the gear ratio. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 02-08-2004, 05:29 PM
We really need more info, especially on the heads. Are they aftermarket or stock. What kind? Casting numbers?
Old 02-08-2004, 06:12 PM
Robbie's Avatar
heads are cast iron world sportsman -2 heads #955-011250-1
i got them from jegs
Old 02-08-2004, 08:40 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
You're well over 400 horse with that combo. My vote is right around 430-450 horse. Take a look at ryan's stroker page and you'll see combo 42 is similar to yours and makes about 414 horse. You've got a roller cam instead of the flat that they've got, your cam is a little lumpier, and your intake is much more aggressive. 450 horse.
K
