Can anyone give me the rates of Stock SB Chevy HP & Torque??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2005, 01:54 AM
Jeeps Are Us!
Last journal entry: The Paint Shop
Hi!
I will appreciate if someone can give me the 350 Chevy (stock engine which I belive produces 160 horses, but the Torque has not been mentioned anywhere?)
Horse power and Torque.
I was also wondering if anyone can guess how many horses my Pontiac 400 engine is making? Very old enigne with no modifications and Quadrajet stock carb, but has stock air gap intake( it looks like air gaps)
Thank you very much.
Houman
Old 05-07-2005, 02:09 AM
willowbilly3's Avatar
Last journal entry: Body mods
Over the years Chevy made dozens of versions of that engine and even a few different ways of rating them. Maybe some good reader has that info at hand but you may have to do your own research on it.
Old 05-07-2005, 08:21 AM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
What are the engine ID numbers?
for the chevy: www.mortec.com
for the Pontiac: www.spottsperformance.com/engineid
Old 05-07-2005, 03:51 PM
Jeeps Are Us!
Thanks to all.
I found a lot of information about what I wanted in those sites.
I also found some good info. at nastyz28.com
Old 08-23-2008, 01:41 PM
Most HP ratings for the STOCK engines with limited carburation (2BBL) & less than free flowing exhaust are usually running @ 70-80% volumetric efficiency.
Thats equates to cubic inch size x .70 to .80 for your peak HP rating.
Example???
350 cubic inch small block chevy w/2 BBl carb, low hp cam & single exhaust =
350 x .70 = 245 BHP
High performance factory versions usually are able to fill in the realm of 90-95% vol efficiency
350 x .95 = 332 BHP
355 x 1.1 = 390HP
355 x 1.4 = 500HP
Many rodders on this forum know what it takes to increase volumetric efficiency well over the 100% mark.
A 350 making over 500 HP takes an artists degree of talent. Small Block Chevy experts such as David Vizard & Smokey Yunick were able to reach these high numbers but with only decades of knowledge, & many thousands of hours of reasearch & good ole fashion wrenchin'.
Good Luck to you & your build!
Old 08-24-2008, 02:16 AM
Docc's Avatar
Dry Heat
Last journal entry: along the weird tale..
Perhaps too late for luck on this build..post is over three years old..
Check dates..
Old 08-24-2008, 02:32 AM
Thanks for helping me learn what year it is.
Did you have anything to add,
relating to how most automotive engineer's fabricate/calculate Brake Horsepower ratings?
Bent Push-Rod on Chevy SB 350! 32Hoopie Engine 12 08-08-2010 08:46 AM
sb chevy chevelleracer2002 Engine 9 08-23-2008 07:36 PM
350 and 454/455 V8 stock HP and Torque? Malibu73 Engine 12 08-29-2004 04:36 PM
torque converter 350 chevy jimm Engine 4 03-05-2002 04:39 PM
Chevy SB to Olds BB conversion McSweene Engine 2 09-05-2001 08:13 AM
