Can anyone help me identify this motor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2013, 04:25 PM
My father recently passed away and I am going through his Rod stuff. Came across this motor. He had planned to restore a 1929 model A ford he purchased years back. Is this a ford motor? I looked for identifying numbers but was unable to locate any.If there is anyone out there who knows what it is and approximate value I would greatly appreciate it.
ID:	72117   Click image for larger version
ID:	72118   Click image for larger version
ID:	72119   Click image for larger version
ID:	72120   Click image for larger version
Old 03-07-2013, 05:26 PM
BOBCRMAN@aol.com's Avatar
Yes that is a Ford engine block and head. Probably Model A
Old 03-07-2013, 05:32 PM
Thank you, do you know of a general value?
Old 03-07-2013, 05:51 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Ford A or B. BIG 4-cylinder, has a 201 ci displacement.
There should be a number right above the water outlet on the passenger side of the block if it was a production automotive engine. If it was a service replacement or an industrial engine there might be no numbers, or different numbers than used for automotive apps.
The model A numbers started w/either A or a combo of A and F. The B started w/A and B, or just B. Canadian engines started w/C followed by A or B.
The Following User Says Thank You to cobalt327 For This Useful Post:
Richiehd (03-08-2013)
Old 03-08-2013, 02:32 PM
Banned
Looks like the engine out of a Ford 2N. Could be for the A though, measure the bore with a tape measure to get a rough idea, it could also not be a Ford at all and some other 4 cylinder flat head.
Old 03-08-2013, 02:49 PM
Thanks for all the help guys. ************
Old 03-09-2013, 10:30 AM
Wiki Edits: 27
value
The value depends on how complete the engine is and how much work-parts are needed to get it in good running condition.If just cleaning, scuffing the cylinder walls and new gaskets, it would be worth more than one that needs new babbet bearings, rebored , new pistons, rings, valves and guides etc.
antique, engine, ford, model a, motor
identify caddy motor? unicorn39 Engine 4 03-11-2013 07:32 AM
Identify this GMC Truck Motor Joe G Engine 14 05-08-2012 03:01 PM
learning how to identify the size of an oldsmobile v8 motor sean 1968 olds Introduce Yourself 2 01-01-2011 06:52 AM
Mopar Engine ~~Can you Identify this motor? Rob Keller Hotrodders' Lounge 10 04-21-2008 01:10 PM
Can you identify this aftermarket wiper motor? RodFather General Rodding Tech 2 06-25-2006 10:52 AM
