most stalls r smaller than stock around 10 or 11 in diameter,, it may not b a stall at all could b u just have a lockup,, but you can allway,s call a trans shop with the casting number,s thay should be abel to tell you more about it,,
Transmission shops generally have no clue how to identify converters beyond what they generally fit, and even then they are sometimes at a total loss. From what little information I have been able to glean from converters I have owned, all TH350C converters are the same. Granted, that may be incorrect as I am not an expert on IDing converters even though I have owned so many in my life. If positive ID is needed, the only place the MIGHT be able to help is your local torque converter rebuilder. |
| The Following User Says Thank You to mmerlinn For This Useful Post: | ||
rock_dog (08-26-2012) | ||
Looks like a 400 converter! 350 converters I have ever owned have the nut an bolt style to mate it to the flywheel to where this is has a lug for a bolt, for it mate to the flywheel.
That is not a 400 converter. Shape, size, and lugs are all wrong for a 400. It is definitely a TH350C converter.
wrks 4 me.
If it is stock it will flash to about 1800 rpm (or maybe a little more- they tend to be a bit looser than non-lock up torque converters in my experience) behind a street/mild sbc 350. It will drop about 200-225 rpm when it locks up going down the road in high gear @ 50 mph (at least that's what mine does). Last edited by cobalt327; 08-27-2012 at 10:34 PM. |
| Please Help Identify | riesman20 | Engine | 1 | 09-15-2007 10:32 AM |
| Help me identify this.......... | 53_belair | Transmission - Rearend | 2 | 11-09-2006 09:17 AM |
| Can you identify these? | Brazz_04 | Hotrodders' Lounge | 10 | 09-20-2005 11:58 AM |
| Help Identify this for me | Angelshock23 | Engine | 5 | 10-15-2004 10:51 AM |
| who can identify | budman | Engine | 0 | 10-08-2002 06:54 PM |
