Can Anyone ID this carb # - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2002, 02:05 PM
roys63's Avatar
Post Can Anyone ID this carb #
Can anyone ID this carb # 9772SA,I have 2 of these that are like the Marine Type 750 AFBs , both carbs only have one vacuume port for Dist advance.Look like a matched set never run.Haven't found anything on the net on these.Thanx in advance. Scott
[ November 10, 2002: Message edited by: roys63 ]</p>
Old 11-10-2002, 12:23 PM
roys63's Avatar
Post
Old 11-10-2002, 01:15 PM
Post
ROY THESE ARE THE VERY RARE IF NOT THE ONLY ONES MADE! FOR THE BOTTOM HALF OF THE tranquility BASE MOON LANDER QUESTION IS"HOW DID YOU GET EM" WHEN TRANQUILITY BASE IS STILL SITTIN WHERE IT LANDED BACK IN 69??? WHAT THE HECK! CHROME THEM + STICK EM ON YOUR CAWFEE TABLE
Old 11-10-2002, 01:42 PM
roys63's Avatar
Post
Yes i think that they are the only ones made!, i had 6 ,Itis said that they were test carbs from Carter-Weber about ten years ago? We run some on a BBC blower setup and they worked real well, I just was wondering if had a Application buy the #s like on a BB Dodge?
Old 11-10-2002, 03:02 PM
MI2600's Avatar
Member# 3287
Post
I couldn't find it in my Carter references. But, then they didn't show a Carter I picked up, #3345S, either. Mine has also got the one vacuum port and some kind of pressure relief mechanism on the front on the passenger side, i.e. on the opposite side of the accelerator pump. I finally found out it was for a Gray Marine 327 Chevy.
Old 11-10-2002, 04:10 PM
roys63's Avatar
Post
I just listed the last of these on ebay i hate to see them go but i need to make some space.Yes these are a marine type carb.
