can anyone identify this camshaft? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2011, 02:09 PM
tyl tyl is offline
hello I'm building a low budget 283 chevy found a new hyd.flat tappet camshaft but don't know what it is....
it says 115806 and 260591 anyone an idea?
sorry for my bad english....I'm from the netherlands
thnx!
Old 11-13-2011, 01:06 PM
The only thing I can suggest is to do a Yahoo search on those numbers with key word camshaft.
bt
Old 11-13-2011, 01:40 PM
techinspector1's Avatar
Wiki Edits: 326
thnx!
With the block on an engine stand, install the crank and one rod/piston in the #1 hole. Install the camshaft with the timing set you intend to use. Install a degree wheel on the crank and bolt a wire pointer to the front of the block. Purchase a cam checker of this type....
http://www.powerhouseproducts.com/ph...m-checker.html
...and degree the cam per instructions....
http://www.iskycams.com/degreeing.php
Once you have established the 0.050" tappet lift specs, match the static compression ratio to the cam. This is just bass-ackwards of the way this should be done. Normally, you would establish the static compression ratio you want to run and then match a camshaft to the SCR to achieve the desired results. The tools to degree the cam will cost more than a new camshaft on which you know the timing to begin with.
http://www.crankshaftcoalition.com/w..._compatibility
Read through this list of don'ts before you begin with a flat tappet cam...
http://www.crankshaftcoalition.com/w...ips_and_tricks
Old 11-14-2011, 11:31 AM
This is the Camshaft Machine replacement cam for the GM part number 3863151 small block Chevrolet hydraulic lifter camshaft (350 HP 327 cu.in.). This is a single pattern camshaft having 222 degrees duration at .050" cam lift. Lobe lift is .298", for a gross valve lift of .447" with the standard 1.5:1 ratio rocker arms. Lobe separation is 114 degrees. Cam timing at .050" is: intake opens 1 degree BTDC, intake closes 41 degrees ABDC, exhaust opens 50 degrees BBDC, exhaust closes 8 degrees BTDC.
Old 11-14-2011, 12:25 PM
tyl tyl is offline
thanks! searched for hours don't know how you got this info but many thanks
think I'll put it in a little wild but with manual transmission and short gear ratio it will make some revs I think
help identify this erson camshaft blndweasel Engine 7 01-10-2015 06:44 PM
Identify this car please freedom53 Body - Exterior 19 01-30-2008 11:59 PM
identify camshaft wildroot60 Engine 1 06-18-2006 08:12 AM
Identify this car please! Nightfire General Rodding Tech 28 01-17-2005 03:47 PM
anyway to identify cam? LoudMalibu Engine 1 02-14-2003 07:25 PM
