Can anyone identify this piston? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2012, 04:50 AM
andyy's Avatar
To check what was the compression ratio I need the specs for this piston
(ex block 10243880 4 bolt 350 CID):
GM (performance?) 940036 6106
Thanks for help
Andreas
ID:	63217   Click image for larger version
ID:	63218   Click image for larger version
Old 02-21-2012, 05:26 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Looks a lot like the Vortec piston I took out of my 880 block. If so, it's 11cc.
Old 02-21-2012, 07:51 AM
maverickmechanic13's Avatar
I'll have a beer with that.
Last journal entry: My Trans Am
I agree. Definitely looks like a vortec piston. The number you are looking for to identify the piston, is actually inside the piston head, not the skirt. It should be inside the piston head, next to the rod, between the two holes, and off to the side. if you cant see it due to carbon buildup spray some choke cleaner / brake cleaner in it. Google that number and you should find all you need about it. The rod should have a stamping on it as well ( i believe its on the opposite side of what the picture you took shows). The rod bearing, if its to wrecked should have a very, very fine stamping of the oversize, if any, and/or/maybe cast# or part#.
Hope this helps.
Old 02-21-2012, 08:07 AM
andyy's Avatar
Oh thanks, I will looking for the right number as you described it.
Andreas
Old 02-22-2012, 10:04 AM
sbchevfreak's Avatar
Licenced Automotive Technician
Looks like it's #8, lol!!
J/K, thought I'd be a smarta##, as you already got the correct info.
identify a piston - shot in the dark ddrumguy Engine 0 08-23-2010 08:03 PM
Old TRW Piston Part # 234-98 396 Chevy Forged Piston? heathj1 Engine 1 07-21-2009 05:14 PM
positioning piston rings on piston geormor9 Engine 5 03-21-2009 05:33 PM
RE:Flat Piston To Domed Piston Bgcooley Engine 10 09-04-2007 12:59 PM
help identify kb piston roy383ci Engine 4 02-26-2007 07:21 AM
