can anyone tell me what steering box this is - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2011, 07:42 PM
awert's Avatar
58/58
I hope this picture turns out....this box is suppose to make the mid 50's to early 60's manual steering into power steering....I'm thinking a saginaw 605.... but what do i know..
Old 01-16-2011, 07:45 PM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Have a look here I think I see it.
http://www.shopwiki.com/Chevy+steering+box
Old 01-16-2011, 07:46 PM
awert's Avatar
58/58
and what about the putnum are?? what did it come off of, i can't make out all the numbers...
Old 01-16-2011, 07:56 PM
pepi's Avatar
cannot help you there. I just saw the box a 55 -57 I believe the 605 one.
I blew up the picture you posted and it looks like 3713 487 and the lower number 611 3 does that look like what you see, you have the box or just a picture?
Old 01-16-2011, 08:49 PM
awert's Avatar
58/58
I took the picture from a add that said "this will turn your 57-58-59 ford into true power steering" $599....I think it is nothing more than a sagnw 605....but the are I-DA-NO.....it's not stock 57 ford.....
Old 01-16-2011, 08:53 PM
awert's Avatar
58/58
good eyes, I think your right on the numbers,,,, now to find out what they mean so i can ID the part....
Old 01-17-2011, 03:09 AM
3rdmember
sure ain't no 605...
looks like a modified toyota pickup box to me..
http://extremegearoffroad.com/images/toyota_ifsbox.jpg
Old 01-17-2011, 05:27 AM
Wiki Edits: 27
steering gear casting no's
different internals can go into the same castings. I remember in the factory when they sent in Mercury parts to the Truck plant. everything bolted up. at the end of the assembly line the driver almost drove thru the seat cushion shop. the truck went left when he turned the steering wheel to the right .. opps. dodge trucks and chrysler cars shared the same castings with different internal parts. the same problem when the wrong part was bolted in.
Old 01-21-2011, 01:57 PM
It looks a lot like a modified late 90's Isuzu Trooper box . I believe it's also an modified Isuzu box Borgeson use in there Mustang power steering
http://www.theautopartsshop.com/Sear...sa+Parts+Brand
Old 01-21-2011, 05:42 PM
It's a GM 600 box. Newer version of the 605. You will find it on the Colorado and models based on the same chassis.
Old 01-21-2011, 09:17 PM
pepi's Avatar
http://extremegearoffroad.com/images/toyota_ifsbox.jpg[QUOTE]
You sure about that? put on your glasses and look at the picture again, they both are black with that silver thing sticking out. However that is as close as it gets..
They do not even mount on the same side of the frame another little problem. "sure ain't no modified toyota pickup box "
Old 01-22-2011, 04:44 AM
Here is a pic of a Isuzu box going on a Mercury. Cut of the mounting eyes and weld on a new mounting flange and it look 100% like the conversion box.
http://www.customrodder.com/tech/070...ion/index.html
Old 01-22-2011, 06:07 AM
3rdmember
[QUOTE=pepi]Quote:
ok, we're both wrong but at least i was closer..
i'll have to keep the isuzu box in mind, i still think i want a 59 ford 4dr sw sometime...
Old 01-22-2011, 06:44 AM
RippinRon's Avatar
And guess who made the Colorado!?? It wasn't Chev.
Old 01-22-2011, 07:07 AM
3rdmember
how'd this turn into a pissing match?
manual steering or power steering pat63chevy Suspension - Brakes - Steering 5 02-03-2007 04:40 PM
Putting on new air bag steering wheel on a older steering collumn. CruisingRam Interior 10 12-20-2004 03:34 AM
85 K5 Steering rally4x4racer Suspension - Brakes - Steering 0 01-08-2004 06:45 PM
Power steering chatter in steering wheel jpd37 Suspension - Brakes - Steering 10 05-19-2003 03:59 AM
Loose steering even though steering box is relatively new? 72Nova Suspension - Brakes - Steering 8 05-14-2003 03:09 PM
