Can bad booster kill engine at low r's? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2012, 06:28 PM
bullheimer's Avatar
NEVER use credit cards!
my daught's Olds Bravada dies sometimes when she brakes and the vacuum hose is good, so i am thinking a bad booster unit? seems like it is sucking all the vacuum away from the motor. or am i all cracked out?
if so what else should i look at?
Old 06-01-2012, 06:36 PM
LATECH's Avatar
It happens. Seen it a few times in the past year. Booster leaks vacuum, sometimes and sometimes not, gets worse more consistent.
Do you hear the vacuum leak inside while applying brakes? that is a good indicator.
You can pinch the hose or block it, and try it to see if the symptom dissapears, just to check, easiest thing to start with.
Fact is stranger than Fiction
Old 06-01-2012, 09:11 PM
bigblockragtop's Avatar
happened to me on my old ford work van
Old 06-02-2012, 10:57 AM
bullheimer's Avatar
thanks you guys
Old 06-30-2012, 04:19 PM
bullheimer's Avatar
update
replaced the booster unit and ......... fixed. double thanks.
bad booster? studeman Suspension - Brakes - Steering 13 01-08-2007 09:46 AM
Bad brake booster? NOlowrider Suspension - Brakes - Steering 4 05-26-2005 12:39 PM
Opinions: Is driving at a low RPM bad for your engine? hlweyl Engine 10 09-17-2004 08:04 AM
brake booster, low vacume bigbadchev Suspension - Brakes - Steering 4 03-03-2004 02:37 PM
low oil pressure, but no bad engine noise Ledslnger General Rodding Tech 15 11-30-2003 09:30 AM
