Can A Bad Speedo Connection Cause No Reverse And Only 1 Forward Gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2004, 08:51 PM
CMROGRL's Avatar
New Member
I BOUGHT A 94 DODGE SPIRIT 3.0 AUTO OVERDRIVE..THE TRANS WILL NOT GO IN REVERSE AND ONLY HAS 1 FORWARD GEAR...DONT KNOW IF IT IS 1ST OR 2ND ...oops sorry about the capps.. when i drive it the speedo doesnt work either...could this be electrical or sensor problem or is it internal big bucks for sure...
thanx for your input , cmrogrl.
Old 02-22-2004, 09:07 PM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
It could be a computer problem or the transmission may need rebuilt. there is no way to know without puting it on a comp scanner.
Old 02-22-2004, 09:44 PM
BOBCRMAN@aol.com's Avatar
Those trannys are known for speed sensor problems etc. You have to put it on a diagnostic machine to find out.
Old 02-23-2004, 07:41 PM
airworld2's Avatar
no speed o
no reverse is a inside problem. no speed o if there is no sensor on right tail housing near axle shaft would most likely be output speed sensor and that would cause trans computer to go to limp in and that result will be 2nd gear only, and you we still have reverse. tranny shop time on this one
airworld2
