Can car sit in 2K high build? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2011, 04:00 PM
Ok, I have shot the epoxy then followed with a 2k high build primer to get the good chemical bond. Will it be alright to leave in sit in a unheated garage over the winter or do I need to get a base coat on before i gets too cold? Grayle
Old 09-26-2011, 05:41 PM
BarryK's Avatar
In the garage it will be fine best state is in an un-sanded state but if it is sanded, then re-sand before you apply more next year.
Old 09-26-2011, 06:39 PM
DARK SIDE's Avatar
2k
mine sat for 3 years...no worries
Is 400HP too high for build?? lizardking7750 Engine 22 06-28-2010 08:59 PM
Need info: T-400 build up for high RPM use charliev12@uk2.net Transmission - Rearend 1 12-24-2009 08:14 AM
help 2kurethane high build? brandonA. Body - Exterior 5 11-01-2009 09:38 PM
What grit before 2K high build Ripped Body - Exterior 16 02-17-2007 11:24 AM
high build primer malibu350 Body - Exterior 4 05-30-2004 09:36 PM
