Can a cast crank handle boost? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2008, 05:11 PM
BMM BMM is offline
Hey guys. Looking into engine options, and and looking ahead at the possiblilites. Will a Scat cast crankshaft with forged pistons and rods be able to handle boost? Nothing crazy, but Im just looking ahead in a few years If I wanted to run mild Forced induction if Id need to swap to a forged crank.
Thanks guys.
Old 09-01-2008, 06:18 PM
Wiki Edits: 31
yes, but you can't go crazy with the boost..
Old 09-01-2008, 07:46 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
I'm going with matt167 on this.. 6-8 psi. Keep the R's in check. No detonation whatsoever.
Ring gaps are important too. N/A motors can get by with less. So if you set it up as such, then later boost it, you may butt a ring and pull a piston apart.
Something to consider.
Old 09-01-2008, 08:12 PM
BMM BMM is offline
So if I set it up (ring gap for example), without running boost, would there be any negative affects on the motor?
Thanks guys.
Old 09-01-2008, 08:21 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Which engine are you planning on doing this to? I've got a 9.7:1 two bolt, cast crank 350 that I supercharged almost three years ago. I used a 142 ci Weiand blower and have it putting out 6 psi of boost. The only problem I have is that I cannot run straight pump gas with it.
C-10's Avatar
Revolution Calling
BMM,
Ring mfr's give a number on a chart that has the intended use, (N/A, turbo, alcohol, nitrous, etc.) This number multiplied by the bore size is the number you should adhere to.
It's all about heat at the top ring land. As you know metal (rings) expands when hot. So it's up to you to gap them accordingly.
Build it tight for N/A NOW, then boosting later, is asking for it.
Lot's of boost= lot's of heat..
Old 09-02-2008, 10:23 PM
BMM BMM is offline
Aye, makes sense. Thanks guys. I guess if I build it Ill do it properely for N/A now, and worry about changing if I want to boost in the future.
Blazin, I gotta rebuild or do something with my stock 350 SBC. I dont know just what yet though.
is there a visual way to tell cast from forged crank? MM in NM Engine 4 11-17-2005 08:03 PM
Can't figure out what crank I have Mad Maggot Engine 3 11-06-2005 09:20 PM
Scat forged or cast???? 406chevelle Engine 13 06-20-2003 05:12 AM
WERE CAN I GET A CRANK AND RODS TO HANDLE 1200 HORSE?? bigbad66chevelle Engine 4 03-29-2003 02:22 PM
balancing a cast crank 85 regal Engine 12 02-09-2003 06:01 AM
