can a cast iron upright bend? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2005, 09:04 AM
I seem to have bent my left suspension upright, it is made of cast iron. Is it possible for it to bend? I though cast would generally just crack. Not sure which part to replace, but the upright on the left is definitely shorter than the right. Anyone know anything about how cast iron reacts to impact? Cheers
Old 12-30-2005, 09:19 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
I have seen many cast iron control arms bend without braking. This is very common.
Steve
Old 12-30-2005, 09:33 AM
poncho62's Avatar
Wiki Edits: 5
It's like bending aluminum wheels...They will bend.....but, they always break when you try and straighten them.
Old 12-30-2005, 09:43 AM
Thanks for the info!!!
Suspension parts are not cast as far as I know, they are "forged" which is much less brittle. They look like they are "cast" and they will bend. I replace them all the time. HOWEVER, they are very strong and you usually have OTHER weaker parts that bend BEFORE the forged part. So you likely have other parts or mounting points damaged as well.
What kind of car are we talking about?
What are the symptoms? (do you have an alignment print out or is it visual?)
Exactly how did the wheel get hit? (top, bottom, front bottom, front upper, was the tire turned when hit)
Old 12-30-2005, 05:46 PM
Some suspension parts are forged, some are cast. Like a crankshaft you can tell by the parting line - wide & flat = forged, narrow & sharp = cast. The castings are however STEEL not iron, like non sd/ho Pontiac v8 conrods.
Steering arms are generally forged but some stub axles are cast. As to impact, I've seen long M/Benz stubs bend when weaker components didn't - it's all in the angle of impact.
Old 12-30-2005, 09:17 PM
Thanks for replies. As far as I can tell it was hit from the bottom left, quite a hard knock, as it managed to break the tie rod too. The car is an alfa 147. I measured the left side upright and the rightside upright from the top to the middle of the driveshafts, the left side one is about 10mm shorter. THanks again!
Old 12-31-2005, 05:30 PM
Well, I certainly can be of much help being I don't know the car at all. However, if the tie rod is broke, there are plenty of other things likely damaged. I don't know if you mean a "Tie rod" or a "tie rod end" which usually breaks first. If the tie rod end broke it probably was turned one way or the other to lock and the wheel was forced further.
Change the "Knuckle" (upright) and the tie rod end and see where you are at. I had the silly idea I could help you but without looking at car that I am not familier with, it is next to impossible. All I do know is there are likely more damaged parts than what you see.
Old 01-01-2006, 03:59 AM
Brian thanks again! Unfortunately, the tie rod, not the tie rod end is broken. The tie rod has been roughly welded together, the steering box is fine but, the tie rod is connected by a ball joint, so Im assuming I will have to change the whole steering box.. The car drives as is, but I dont want to drive it around for fear the tie rod will snap again. There are other damaged parts for sure, the frame could be a little out too. Cant tell.
Do they have cast iron 9" housings?? 84Z Transmission - Rearend 2 09-04-2005 11:55 PM
Welding Cast Iron OneMoreTime General Rodding Tech 3 01-22-2005 06:46 AM
Cast iron powerglide slingslingbinks Transmission - Rearend 13 09-30-2004 11:18 PM
Brake parts cast iron or cast steel brainsboy Suspension - Brakes - Steering 0 05-26-2004 04:42 PM
Cast Iron Crankshaft RPM Limit ? bigjoedo Engine 6 11-24-2002 04:49 PM
