Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Can closed cell foam be butted together?
Old 11-11-2009, 02:57 PM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
Is there a method for butting up two pieces of 1/4" closed cell foam without the seam telegraphing once the upholstery is glued on? Or won't it telegraph if the seam is perfect?
For the particular area I am working on (compound complex curve at the rear corner of the panel delivery) I do have the option of butting the 1/4" and then applying a layer of 1/8" over the top of that, which hopefully would do the trick. But if there is an easier way it would make my life a little easier.
Always learning...and sharing what I've learned.
