Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Can closed cell foam be butted together?
Old 11-11-2009, 06:43 PM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
What do Don Taylor and Ron Mangus say? It's foam, and foam can be glued together. Why not seam a layer of 1/8" foam and then put a full layer of 1/8" foam over it to get the 1/4" you want? The first layer will still need to be scuffed, so do a very good job of scuffing. How wide is the foam you're using? It's much easier to buy it 72" wide, then you don't have to worry about any seams.
