Can drums/rotors be balanced? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2012, 08:38 PM
Banned User
i heard from a former midas worker that rotors/drums can't be balanced, but i'm thinking they can.
What is the low-down on this?
P.S. This ties in with the thread that i started entitled "overdrive vs. direct drive+high gear."
Old 09-27-2012, 09:02 PM
Anything that turns can be balanced. That being said a brake shop probably doesn't have the equipment to do so. Ask a good automotive machine shop if they have the properequipment. Drive shaft makers also.
Old 09-27-2012, 09:23 PM
SSedan64's Avatar
Drums & Rotors come balanced from the Factory or Remann shop. Unless they are severely worn they're probably fine.
You can see the round Lead weights on these Al. Drums.
http://www.bowtiepower.com/images/drumoutside.jpg
Cast Iron Drums with rectangle weights.
http://www.britishv8.org/articles/Im...ession6-DD.jpg
Old 09-28-2012, 07:28 AM
This is absolutly true.
Old 09-28-2012, 07:38 AM
Wiki Edits: 27
rotor balance
I have an old Bear spinner wheel balancing Machine, It has a couple sets of mounting plates with multiple holes for different wheel patterns. When you can't match up the bolt holes there are a couple cones with a one inch bore used to mount a brake rotor or hub, Static balance is easy. To spinn balance a rotor I would have to change out the steel driver wheel that contacts the tire . I have seen quite a few rotors with large Roll pins pressed into the cooling fin holes. Just like drive shafts I don't like using one that has a lot of balance weights.
Old 09-28-2012, 08:17 AM
This month's issue of Auto Restorer magazine had an article about balancing rotors. The author used a cheap Harbor Freight motorcycle wheel balancer. It's easy to put balance weights in between the fins on a vented rotor. Solid rotors and drums are tougher - drums require welding, solid rotors require drilling holes.
Tires need balanced Spooker Hotrodding Basics 2 05-13-2011 11:51 AM
externally balanced vs interally balanced? bwomp969 Engine 7 06-15-2009 03:47 PM
Should I get my engine balanced? maxpower_454 Engine 21 03-20-2009 09:13 PM
How is the 429 balanced? HOUCKXLR8 Engine 3 04-03-2007 10:03 PM
balanced engines bigwildgrin Engine 58 12-30-2003 07:19 AM
