Can the dual coil valve springs on a BB destroy Valve guide seals - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2003, 03:27 PM
Auto-Part's Avatar
Some dude at work claims that if one installs dual coil valve lifter springs on a BB. The springs will destroy the valve guide seals. Any truth to this claim
Old 11-25-2003, 03:45 PM
Yes, on the OEM BBC heads you have to cut down'
the guide bosses for smaller seals. Also you need to
use a spring locator seat to properly control the spring
on the head.
Cstraub
Old 11-25-2003, 04:49 PM
NorthStar's Avatar
message deleted
Old 11-25-2003, 05:03 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Of course, early hemis came with dual springs and hardened seats from the factory so this isn't an issue!
Old 11-25-2003, 05:23 PM
Auto-Part's Avatar
Dam!!! I hate when that dude at work is almost always correct.
I would also like to say thank-you for the info I will pass this on to the guy I sold the 73 454 vette to, he called me complaining that the Vette was going through 1 quart of oil every 500 miles. When I installed the 272 cam. I did upgrade the springs to the dual coil and to roller tip rockers. I guess I will pay for the installation of a new set of valve guide seals.
