Don't blame a cam manufacturer. I bet that most of the cams sold today are flat tappet cams. |
To answer your question... the 96+ Vortec 350's had roller cams.
You can use a flat tappet cam, but you'll need lifters (obviously, usually replaced anyways) and longer pushrods and ditch the cam retaining plate on the front of the block. The engine I'm building had a flat tappet cam in it, and it's a 4 bolt main, one piece rear, roller cam block. I am pro-roller motors and am using roller valvetrain now. |
I've been using solid flat tappet cams for about thirty years now. People started
complaining about wiping lobes about the time when one of the largest lifter manufactures went out of business. The quality of lifters went down, only one or two top manufactures are left in business. Some people say its the oil, I say its the lifters. I buy all of my flat tappet lifers from Isky, they don't manufacture lifters, however the quality is there and I never wipe a lobe. Some of the major cam manufactures sell junk lifters, you will know if you buy then, you will be changing a lot of cams. |
Hi ScoT,
I can buy Chevy solid lifters for $120 or $39. I don't know that there's any difference between the two but I would bet there is. With everything coming from offshore, do we know the quality of anything anymore? One thing for sure, if the taper isn't ground correctly on the lifter face, you will lose a lobe or two in a heartbeat. To make things worse, cams can be ground with very aggressive ramps requiring high spring pressure to keep everything together. With a flat tappet I avoid both. As for the oil fed lifters, I haven't tried them, it sounds like a good idea. I do keep the oil pressure up and avoid extensive idling. Tom, Do you know the details of the build that lost the lobe. Radical cam? What brand lifters? |
I personally have never seen the need for anything more than the flats for street use. I do agree with quality issues as mentioned above though... Luckily there is a company here by me that I can just give my desired specs to and they grind me a top quality piece.
In your application I would probably go with a roller simply because that is what the engine was designed for. You can modify for a flat but unless you know what your doing you may do more harm then good. |
I agree with the crapshoot,
You can calculate every angle, check every clearance, use the right springs, lifters, and cam for your application, degree the cam, use the isky rev lube, break it in with Brad Penn "green" break in oil.... And still have problems. The only way to know for sure is to use a roller. The direct oiling solid lifters seem to help a little but they aren't used on hydraulics. |
But I've long held that the hand writing was on the wall for all to see. When the OEMs switched to roller cams, that was clear notice to all concerned that they felt that flat tappet designs lacked the necessary long term durability with these new oil's that were EPA restricted in the use of metallic dry EP lubes within the oil's additive package. I think you need to find out whether or not your block has or is equipped to have a roller before you start spending money. First place to look is the block casting number, this will tell you if it's a roller prepped block or not. Look for these casting numbers to identify a 350 roller block 10243880, 14011148, 14088526, and 14093638. Be careful of 14011148 as there is a close number 14101148 which is a flat tappet block. Having one of those numbers means the block has the provisions for a roller cam, however, this doesn't mean it has a roller cam as these blocks will accept a flat tappet cam and the factory kept some usage of them in truck engines thru 1995. Remove a rocker cover and shine a bright light into the valley, if you can see the tops of the lifters and they have a guide that attaches them in pairs you're looking at a roller. If you can't see in there, the next check is push rod length. Back off a rocker that's sitting with the valve closed as you'll have to readjust the lash when you're done. Remove the pushrod to measure it; the OEM roller pushrod length is 7.195 inch for the taller roller tappet; the OEM flat tappet pushrod length is 7.795 inch. If you have a roller, I'd certainly not consider going back to a flat tappet. If you have a roller block with a flat tappet, I'd convert the thing to take advantage of the OEM roller, parts to do this can be had from GM or the aftermarket. If this is a flat tappet, I'd recommend that you include a cam button to take the thrust load off the tappet/lobe interface this will help these guys survive in a world of reduced EP additives. Also, follow the cam manufacturer's break in procedure to the letter. Bogie |
cams
Since the big lifter deal that hit almost every engine builder, I check the crown of every flat tappet lifter I install. Back when all this was going on I would find 1 or 2 lifters per set that only had .001 or less crown ground on them. My tolerance was: if the lifter had less then .0015” I would not run it. I never lost one single flat tappet cam since I started doing that. Now that required me to have at least one broken set laying around to pick extras from. The correct crown is .0022”
During that time I was building 358 limited late engines that had to be flat tappet cams not rollers. They were some very aggressive lobes on those cams. I had zero issues with them also. But I followed my procedure to a “T” I have an entire song and dance I go through with a flat tappet engines when I build them., It’s a bunch of extra work. For me personally I will do what ever I can to talk the customer into going roller. There is almost a zero chance of having a problem with them, that means no come backs… There are a lot of shops that will not build flat tappet engines any more. I explain the deal to the customer and let them know I have zero responsibility if the cam eats a lobe, and that the engine will need completely torn down and cleaned if it does, on there dime…I let them make the choice. So, the choice is yours. The flat tappet cams work, but for the average guy the peace of mind that comes with installing a roller is worth the little bit of extra $$$ spent up front. As a reminder, if the cam fails the money to R&R the engine is more then the extra money needed to go with a roller… I built 10 engines this year, 8 were roller, 2 flat tappets. Keith |
They called Lunati and they don't even offer P-55 cores so both called Tim at Bullet cams and got the P-55 cores. We use alot of flat tappet cams with no problems hyd. lifter we buy them right from GM and soid lifter we buy the tool steel lifter and no problems. And we have our cutomers use the reccomended oil and cam break in is important with proper springs or break in rockers. |
all 16 lobes receive the same induction or flame hardening Rockwell finish at once so all the lobes would/should go flat if the cam is at fault.....
the Crane Cams site states that they have yet to get a flattened lobe cam back with less than 55(?) Rockwell hardness finish.... there are millions(?) of assorted "stock" flat tappet motors (lawn mowers/generators/inboards/fork lifts/whatever) sold every year and they don't have a wiped out lobe problem.....(even using today's oil and lower Rockwell finish) the single lobe failure problem source is very probably not the camshaft itself |
This cam had 360 over the nose and 140 at the seat. We have P-55 cores with 430 over the nose and 170 at the seat and no issues. |
| Which oil/additives for flat tappet cams? | Sinister | Engine | 6 | 04-12-2008 02:15 PM |
| New Flat Tappet cam - New Bearings?? | Lloyd1wv | Engine | 3 | 12-19-2007 06:37 AM |
| Break in oil flat tappet cam | 71 c-10 | Engine | 5 | 11-17-2007 09:55 AM |
| Know of any good cams? | TurboS10 | Engine | 19 | 12-20-2004 01:46 PM |
