can flatheads be mounted to engine stand by bell housing bolts? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2006, 02:27 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
any reason a 49 flathead can't be mounted to a conventional engine stand by using the bell housing bolt holes? thks bob
Old 12-28-2006, 02:40 PM
dorksrock's Avatar
that one hot rodding kid
theres no reason you cant. i put my '50 flathead on my engine stand by the bellhousing bolts. Hope this helps!
-Jordan
Old 12-28-2006, 03:02 PM
Heck, my 59A flathead has been on an engine stand for years waiting for me to use it for something other than a hat rack, and that's the half-bellhousing early style engine. Your 8BA could live on a stand forever, I imagine.
Old 12-28-2006, 04:55 PM
37ford4dr's Avatar
bobs77vet
thanks, sounds like a plan to me
Old 03-16-2012, 01:32 PM
Flathead engine stands
You might find it easier to work on if you make up a mounting plate that bolts in place of the exhaust manifold, using all the bolts. Works good for me, and you can get to the flywheel and clutch while it's on the stand.
Cam Help black66 Engine 3 05-12-2003 06:15 PM
C-4 Bell Housing to 5 bolt engine melbishop Transmission - Rearend 3 06-09-2002 09:55 PM
