can it handle - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2003, 06:32 PM
low77ride's Avatar
can it handle
I have a totally stock 350 in a 77 monte carlo can my motor mounts and for that matter everything handle a 2000 stall converter? Or will i run into some serious problems ? The tranny is a th350 with a shift kit. rear gear is 2:40s around there but i plan to change it to 3:73 posi. thanks
" You cant piss on what you cant catch"
Old 11-16-2003, 07:04 PM
poncho62's Avatar
Wiki Edits: 5
Change to the 3.73s first, unless you already have the stall converter. It won't do much good with the gears that you have now.
Old 11-16-2003, 07:51 PM
The stall converter will make a big difference but what I would worry about is your cruise rpm being to low to let the torque converter competely couple which will cause huge heat and poor fuel economy. Might be a good idea to go to some shorter gears at the same time.
Old 11-16-2003, 08:02 PM
low77ride's Avatar
yea i kinda was planning on getting the the gears and the stall converter for christmas and maby a locker to but we will see. Will 3:73 rear gears work good with this stall ?
Old 11-17-2003, 05:47 AM
astroracer's Avatar
Before you decide on a converter talk to a couple of manufacturers about your combo and what you expect/want from the converter. The best advice you can get will come from them...
Mark
Old 11-17-2003, 09:46 AM
Decadent pianoplayer
Im planing on a 3.42 for my Camaro '68. Its powered by a 355 Lt1 and a TH350 with ,exactly, a 2000 rpm stall converter. Currently I have a 2.73 rear-end and I cant say the stall converter did a lot of difference; some but not much.
Old 11-17-2003, 04:05 PM
Well like everything the converter should be matched to the rest of the parts on the car but ya i think consulting a converter company would be a good call.
