Can It Handle A 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2004, 09:16 AM
MARCELO URUGUAY's Avatar
New Member
CAN A 64 3 SPD. O.D. TRANSMISSION HANDLE A 350 CHEVY WITH HEADERS, WEIAND MANIFOLD AND CARTER AFB?
Old 12-22-2004, 09:46 AM
willys36@aol.com's Avatar
Wiki Edits: 21
As long as the tranny isn't worn out being that old, it should handle a mildly modified street engine with no problem.
Old 12-22-2004, 11:54 AM
packratwrecker's Avatar
Too many hobbies!
This a SM318, with overdrive, correct?
If so, I'd be really careful. That 1st gear ring won't take much abuse.
Old 12-23-2004, 02:16 AM
New Member
I DONT KNOW THE MODEL BUT IīM ONLY USING THE O.D. UNIT, NOT THE REST OF THE TRANS. I`M GONA PUT IT BEHIND A TH 350, LIKE A INDEPENDENT O.D.
WHAT DO YOU THINK?
Old 12-23-2004, 08:15 AM
Wiki Edits: 21
Proper etiquette is to not use all caps in posts. All caps means you are yelling at us?
Old 12-23-2004, 10:41 AM
New Member
What?!?!?!?
Whatīs wrong with caps? Iīm not yelling at anyone!!!
Is better this way?
By the way, what do you think about this?
I have a 47 chevy coupe with a 350 v8 and th 350. Also i have a 64 3 speed o.d. transmission from a 64 impala. Iīm planning to make an adapter to put the o.d. unit (not all the manual trans) behind the automatic, like a Gear Vendors O.D.
Because lathe and mill works arenīt cheap down here in sout america i like to listen to the experts before make it.
I think it will work but I donīt know if they will survive much time behind a 350.
Old 12-23-2004, 11:49 AM
Too many hobbies!
Bad idea
It's going to be a big job, to convert the O/D, to an add on affair.
It will make for a looooong tranny, and a short drive shaft. If the O/D is not supported, chances are you will break the back out of your TH350 case.
Above all, You cannot run the it in O/D, when you are in reverse. There is a roller clutch inside, that lets the output speed exceed the input speed. Running it backward will cause catastrophic failure.
It would be handy in a light car, but I wouldn't put it in a big one.
Old 12-23-2004, 08:54 PM
MI2600's Avatar
Member# 3287
Also, the Chevy OD unit was used behind low performance engines.
Old 12-24-2004, 03:32 AM
New Member
Yes, but.....
The od have their own suport, so I only have to make another trans support in the frame. Therīs no problem with the driveshaft (3 foot long) because of the very short suspension travel.
Locking out the overdrive eliminates the reverse problem; I only plan to use it for hi speed cruising. My only doubt is about the ring that locks the od when itīs disengaged.
Old 12-25-2004, 05:00 PM
71ss's Avatar
Por supuesto man, lo unico es que la caja este en buenas condiciones operativas.
Old 12-25-2004, 07:57 PM
What he say?
Old 12-25-2004, 08:51 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
hmmm....
glaub ich dass er 'was auf Spanisch gesagt hast.... was fuer ein Arschloch.... und was fuer eine Scheiss Sprache-
K
Old 12-26-2004, 05:14 PM
Hei 71SS in Venezuela.How much a late 60s Mopar sells for?
Are they relatively easy to find? Paulo
Old 12-27-2004, 04:25 PM
71ss's Avatar
Is cheap here but is dificult to find it. I own 3 camaros 1 is my favorite 71ss blue with good parts in the engine it runs 11s on the street, the other two are a black 68, and one yellow 69 that is out for back half, i forgot a black 93 camaro but is 6 cylinders, i will send the pictures of all. Bye.
Old 12-27-2004, 05:41 PM
Ok 71SS. Thanks for the reply.Eventhough our countries are neighbors we know very little of each other.Here in Brasil we hear that fuel is not expensive in VZ and for this reason many V8 american cars were sold there.How far in hours of driving your city is from the border with Brasil?
