Can I Adapt My Buffer as a Scrubber? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2004, 08:05 AM
New Member
Okay here is one of the weirder posts of the day... I want to use my electric buffer to clean the bathtub - similar to one of those B&D "Scumbusters". Does anyone know where to get cleaning pads (3M type) that I could easily adapt to use for this purpose?
Thanks!
-- Ken
Old 08-30-2004, 08:34 AM
I believe they have them at the hardware store. They make a tool for prepping hardwood floors that uses a similar pad, maybe that too would be an option.
Do you plan on painting that tub? If you do, get a motel for at LEAST a few days, I mean three or four. If you plan on using auto paint that is. The fumes from the flashing solvents will KILL YOU, even a few days later!
Old 08-30-2004, 09:51 AM
New Member
Tha pads I've seen are all for stripping paint or scuffing steel. The pads I'm looking for would be for cleaning. They make them on hand-scrubbers, and B&D has pricey ones specially made for their scum-buster. What I'm looking for are generic cleaning-grade pads that I could use on my buffer.
No I am not painting the tub! This is a "plastic" tub..
Old 08-31-2004, 10:45 AM
Ron M's Avatar
Sounds to me that you are looking for either blue or gray - fine or ultra fine scotchbrite. If you have or find a hook and loop backing, they will work well for polishing and cleaning. I use the ultrfine gray on my bathtub with water, and it works great.
Old 09-01-2004, 07:34 AM
New Member
Thanks Ron. I've been thinking of getting the sheets and cut them into circles for this purpose. Sounds like a plan!
Old 09-01-2004, 07:54 AM
BOBCRMAN@aol.com's Avatar
Back in the early eighties I lived at a place where the iron content in the water was VERY high. A glass of water looked like tea. You had to take a piece of hanger wire and clean the little holes around the underside of the toilet bowl once a month so it would flush. And heaven help the guy who let a faucet drip! The rust would be at least 1/32" thick in a few hours.
I use a Schlegle Wool pad and Barkeepers Friend mixed with Lacquer rubbing compound on my 7" buffer to clean the plastic (fiberglass) tub/shower.
Be VERY careful with Scotchbrite on plastic, or you will be thru the finish quickly.
Old 09-02-2004, 09:04 AM
New Member
That's interesting BOBCRMAN. I was eyeing my wool schlegel pad and thinking of trying it using Sof-Scrub. BarKeepers friend sounds like a good idea also. Maybe I'll go that route...
Old 09-03-2004, 12:11 AM
Ron M's Avatar
Dohhhhh, buffing the gelcoat?
Old 09-03-2004, 08:55 PM
Gr8 '48 bow tie's Avatar
Be American, Buy American!
Try a janitorial supply store.
Al
