Can I disable neutral safety switch?
If I disable a 200r4 neutral safety switch thats on a 305 it will work fine right? Or in other words not hook up the neutral safety switch it will be fine?
Be aware that starting in the late 1970s, GM cars stopped using an electric NSS. Instead, there is a mechanical blocking ring in the steering column that prevents the key from being turned to the START position if the shift selector is not in Park or Neutral. Even floor shift cars used this system since they have a backdrive linkage that locks the shifter with the ignition key. You will see a switch that looks like a typical NSS switch at the base of the steering column on these cars, but it is NOT electrically connected to the starting circuit. Instead, it retains the backup light switch function and on computer controlled cars it provides a Park/Neutral signal to the ECU for the purpose of setting the idle speed and mixture. Again, it has nothing to do with the starting curcuit. |
Nss
You should have some type of safety factor built in. also you could use a relay so the car would only start when the brake pedal is down and the brake lights are on.
Putting 1986 305 engine and 200r4 in nissan 240sx. So basically if i didnt hook up neutral safety switch and started the car in park or neutral it would start up fine?
I know its a very good option to have and I will prolly put it on, but if I were to not hook it up keeping the ebrake up wouldnt that stop it from jumping.
The neutral safety switch costs nothing, it uses no horse power, it weighs nothing (to speak of), it is SUPER simple and doesn't require a genius to install or maintain. It is probably as simple a component as you are ever going install or maintain, with HUGE dividens, why not use it? I have a lifelong friend who used to use toggle switches for starter switches! Well, he wasn't a dummy, he would be the only one driving the car right? He can push the switch forward and pull it back as the car started, it doesn't take rocket science right? Well, he was putting gas in his blown hemi powered 29 Model A roadster and his son sitting in the car turned around to watch and hit the toggle with his foot! The car took off ripping the filler tube from the gas tank and doing some hefty damage to the quarter panel. It was STUPID yet he felt he was smart enough to not need a push button or a neutral safety switch. For goodness sakes, just leave the friggin neutral safety switch there. Brian |
As stated before the safety switch is not part of the trans, one would have to be added/ possibly use the Nissan switch.
Weell I am absolutely sure that no one here ever has a brain jam and makes a mistake,,hook up the switch already..Another thing if you ever entertain going to the strip the neutral safety switch is required to be hooked up and working..it is checked..
Sam
To answer your original question, the switch is just that, a switch. Short across the two terminals in the connector and the car will start just fine. Yes, it's not a good idea to run without an NSS, but geeze people, the amount of nanny-ism in this thread is starting to scare me. People need to use common sense and take responsibility if they don't. How many people here have manual transmission cars WITHOUT a clutch safety switch? How is that any different?
Brian |
Brian |
I belong to a tractor forum....They wont allow talk of disabling any safety switches.....Thing is, many of these old tractors didnt have such switches.
Disabling a safety switch is not a good idea.....use your head in what you do. You will live with the consequences.....maybe
Ontario Rodders |
I currently drive occasionally a 1974 Ford F250 Supercab pickup with 390, and a C-6.
I am trying to get the arm that hooks up to the shift shaft in the steering column, that actuated the neutral safety switch, but so far, I have not been able to get it. The truck was driven about 300 miles last year, and a good part of that was literally moving horse manure from behind a barn out to under some trees, in the back pasture. The emergency brake works on this truck. I am the only one that drives it. I know it will start in gear. So did many vehicles I have had with manual transmissions. Starting in gear is a nice feature, if you ever have a problem with the clutch linkage. I am not dead yet. I also built a VW powered sand rail, in the late 1970's. I purposely put a toggle switch that would stay in the cranking position. It would crank in gear. I knew that, and so did anyone who was around it. My reason for doing that is this. If the dune buggy got stuck in the sand, I had the option of turning off the ignition, putting it in gear, reaching in, turning on the starter, and pushing it far enough to get away from whatever it was stuck on. I used this "feature" many times to get unstuck. Was it "safe"? Probably not. But again, I am here to talk about it. Yes, you should put a neutral safety switch on your car. Is it absolutely necessary? No, but you should. Be careful. Do what is smart. |
| Neutral Safety Switch Help | johns79z28 | Electrical | 7 | 03-08-2008 02:40 PM |
| Neutral Safety Switch on TH-350 | nova69 | Electrical | 5 | 11-22-2007 04:01 PM |
| need help with neutral safety switch | Grey1961 | Electrical | 5 | 12-11-2005 11:22 PM |
| neutral safety switch | zipfactor | Electrical | 2 | 08-30-2003 07:58 PM |
| Neutral safety switch help | insomniac | Electrical | 10 | 10-10-2002 12:00 PM |
