Can I disconnect my computer on my 96 chev one ton dually? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2011, 08:30 PM
Last journal entry: Albany Oregon Show
Hi All
I have a 96 chev one ton dually with 454. Problem is no torque, hp, wont idle right. I want to switch, the cam, springs, rocker arms, and push rods. I also want to go to a Edelbrock manifold and a 750 carb. I hate this fuel injection system. What problems will run into as far as my gauges, tranny, cruse control etc?
Bob
Old 10-17-2011, 11:48 PM
John68040's Avatar
Chances are you'll lose most of the gauges and you will lose the cruise control. Your best bet is to toss the stock gauge cluster and make a new panel with all aftermarket gauges. There are also aftermarket cruise control kits.
Your main problem is that it is a 96, and that's the first year of OBD II. This means that almost everywhere in the country your vehicle is required to be hooked up to a scanner to pass inspection. You also will not be able to pass emissions if your state requires it on a 96 - and chances are they will. Essentially, your truck will be un-inspectable. Even if it will pass inspection where you live, it'll be difficult to sell it if you ever decide to as it won't be road legal in most of the country.
Old 10-18-2011, 06:01 PM
LATECH's Avatar
Find a competent garage and have it diagnosed properly.Could be something simple , could be more complex.
EFI yields good mileage(better than a carb) and plenty of power when operating correctly.You just dont understand yours, that is why you hate it.
It really isnt that complicated, but look for a competent garage just the same.A good tech should be able to explain things so you understand what is wrong with your truck, and how it causes the trouble you are having.
Maybe the cats are plugged,maybe the fuel pressure is to low.
How long have you been driving with the check engine light on?
Old 10-19-2011, 11:10 PM
Last journal entry: 1996 silverado
tossing the computer is a terrible idea. is the truck an auto or a manual? if it's an auto, you'll either have to swap out the 4l80e to something not computer controlled or you'll need a stand alone trans controller computer, which isn't cheap. if it's a stick you could get away with it, but you will pretty much have way too much money into trying to get gauges to work, not to mention the rats nest of wire you would have to remove.
Old 10-19-2011, 11:24 PM
John68040's Avatar
Pretty much. Too much work for too little reward. If you don't want the computer, buy a vehicle without one. That's what I did.
Old 10-20-2011, 01:50 PM
Race The Truck
Last journal entry: Son's Truck
I would go here first! www.fullsizechevy.com
Craig
Old 10-20-2011, 08:43 PM
Thank You for the information. I am now looking at the fast tbi and aux computer. In the end selling the truck is not a bad idea. According to a GM teck there is nothing wrong it was a sled when it was new.
Bob
Old 10-20-2011, 11:21 PM
Yea that is definately true. I was assuming that you noticed a drop in power since you've owned it. I've had about six s10s/blazers 96 through 98 and my 96 silverado, all of them plugged the cat in the time that I had them. I usually buy vehicles with 110 to 140k and they seem to go around 130 to 150k miles. I open up the exhaust and it runs exceptionally well. If you bought this thing with no power, it probably never had any. cams and heads are available to work with your computer, but if you can afford a whole standalone efi system, you are definitely better off with that. assuming it also runs your transmission.
Again, if you have a stick, you don't have to worry about that aspect. Another area to address is gears. usually a truck heavy enough to need a big block have low gears from the factory, but if it's a 2wd, it's probably a higher gear ratio.
Give us a little more information on your truck, someone on here might be able to save you a lot of money and hassle.
I would hate to think a new computer was the answer, tear out all my oem fuel injection **** to put in an aftermarket unit and not be able to go anywhere because my computer now doesn't tell my transmission to shift.
you said its a 96 with a 7.4L 454 cu. in v8 right? auto or manual? 2wd or 4wd? what gear ratio? what size tires? are they super heavy 10 plys? rotating mass is a big factor in helping that tachometer climb faster.
Old 10-21-2011, 10:49 AM
The truck has a 4l80e, its 4x4 with 4.56 gear, its a one ton dually. The fast computer tags on to the stock computer. It runs the fast 4 barrel tbi setup. I have talked to three guys on the internet and they claim it runs seamless. The fast tbi is 900 cfm, more than enough to do the job. The system costs about 1000 - 1100 including the manifold. Edelbrock Performer. I already have a suitable cam, lifters, springs, push rods, and roller rockers. Lunati voodoo 256 #60201lk.
Swapping my engine from computer to No computer,whats the best way?? Schoust Engine 3 03-26-2010 03:31 PM
14 bolt dually vs IH dually rear??? HemmiGremmie Transmission - Rearend 2 02-01-2010 09:49 PM
welding on car what do I disconnect tomthecomic Garage - Tools 8 03-30-2008 09:52 PM
1996 chev 4x4 dually auto 427 desotot Engine 4 09-09-2007 10:47 PM
Dually diff for a '46 Chev PU Sidn Transmission - Rearend 3 12-06-2006 05:49 PM
