can i do it - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2002, 08:53 PM
Post can i do it
have a 77 corvette 350 with 333882 heads,low pro.cam,cat.converter,egr valve,ect.what can do on a rebuild to get more power.can i drop the cat.converter & egr valve,ect in the process?
this is the stock engine,180hp & also has 8.5:1
dished pistons. would like to get around 300hp
or more.
[ August 30, 2002: Message edited by: john69 ]</p>
Old 08-31-2002, 06:35 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Post
If the pistons are forged, at 8.5 to 1 comp, add a small blower or a 125-150 shot of nitrous. Loose the convertor. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 09-01-2002, 07:57 PM
Post
i agree with hemi ,supercharger the way to go specially for street wow factor and least amount of punishment to engine
Old 09-01-2002, 07:58 PM
Post
i agree with hemi ,supercharger the way to go specially for street wow factor and least amount of punishment to engine .stock pistons will be fine as long as you dont go over 8 or 9 lbs boost
