Can I Do An Accurate Compression Test With No Carb? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2011, 02:31 PM
Like the title says. Can I get any readings I can use or do I need to wait?
Old 11-14-2011, 02:52 PM
cal1320's Avatar
Yes and no. You are supposed to have the carb at WOT anyway. The only thing is you will be doing it cold with a vehicle that has sat for who knows how long. If the vehicle has sat a while the reading will be low but it will still tell you if the cylinder pressures are even or not.
Old 11-14-2011, 04:21 PM
1971BB427's Avatar
Compression will change on a cold vs. hot engine, regardless of the carb. So you can get an accurate reading, you'll just have to consider it as an accurate cold reading, and know when warmed up it will probably be better.
compression test help legionlleh Engine 2 03-24-2007 09:07 PM
Compression Test stratt134 Engine 3 07-26-2006 01:58 PM
Compression Test Canadian Charlie Engine 11 06-01-2005 09:39 PM
Compression Test gone bad bonuts Engine 4 07-12-2004 03:10 PM
Compression test blockhead Engine 2 11-30-2002 11:22 AM
