can I downsize caliper - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2011, 09:53 AM
Last journal entry: fan shield
can I down size my caliper without changing the size of the rotor? My problem is I have 15" cragars and the calipers are really close, like a carboards width from the rim itself, so i was thinking if I could just get smaller calipers? Thanks This is on a Ford 9"
Old 06-07-2011, 10:03 AM
ericnova72's Avatar
More for Less Racer
As long as it clears by that much, it will never contact the rim. As long as you have clearance you are good to go. 1/16" would be plenty. If the wheel or caliper bracket flexes more than that you have a bigger problem.
You probably won't find any smaller caliper for the current caliper bracket you are using. If you want smaller calipers it will likely require different mounting brackets also. Lots of smaller stuff out there if you are willing to change mounting brackets also. Try Speedway Motors, Wilwood, Strange, Baer, to name just a few.
Old 06-07-2011, 10:56 AM
slow4dr's Avatar
Like Eric said, a 1/16" is plenty. However, swapping to the Wilwood calipers will gain you a little space and give you more braking performance.
-J
Old 06-07-2011, 11:07 AM
Man that is a relief, I can see daylight between the caliper and rim , but its always good to have another opinion, brakes are something you don't wanna fool with I guess i have to tell the ol'lady she was right AGAIN
Old 06-12-2011, 12:04 PM
Often the tightest clearance is some casting flash sticking up on the caliper. If you take a file and/or some sand paper and knock off the flash it will give you a bit more room if you find you need it.
Old 06-12-2011, 01:54 PM
Irelands child's Avatar
-J
Only if you have the Wilwoods with Explorer type e-brake. The older Wilwoods with the Airheart type e-brake will move +/- .062 or so on the bracket and will contact some wheels - a $900 awww cr@p that I made with my $$$$ aluminum wheels. This is how close these are with the replacement 17" wheels:
Irelands child
Old 06-12-2011, 08:22 PM
yup that is how close mine are I guess I will find out, because on the rack there is no problem with clearence
Downsize carburetor Gordie T Hotrodding Basics 5 12-14-2009 04:24 PM
Which caliper? Tomard Garage - Tools 8 10-14-2008 10:44 AM
Caliper Brackets 2DOOR Suspension - Brakes - Steering 3 11-24-2006 07:41 PM
Need to downsize from my 750vac sec Holley. Want your choice of carb and why! club327 Engine 20 02-05-2006 10:27 PM
Caliper Que. HELP!!! 39chevy Suspension - Brakes - Steering 6 06-03-2004 06:01 PM
