Here is a link to a video on vertical up with a mig. You may have already seen this.
http://www.youtube.com/watch?v=mxAHP...eature=related Hope this helps. |
I've been watching some videos and they all indicated that my wire feed speed was set too low
My weld was making the exact sound that there's was when they showed a weld with too low of a feed speed http://www.youtube.com/watch?v=tw0z2...&lf=plpp_video I had my wire speed set at 8 (out of 10) so I'm already right up there I'm going to do some practicing today with a different setting, but, should I increase the wire speed even more? - it seems like it's already set pretty high for such thin metal? Or, should I reduce the power setting? I can see that my weld had no penetration, so I'm a little hesitant to reduce the power setting, but could this have been due to the lack of wire rather than the power being set too low? As mentioned earlier, the settings were the same for both the vertical and the horizontal welds I had the power set at 4 (out of 8) and my MIG is a Cebora 180 From watching the videos I know my wire speed was definitely too low, but since I'm already at speed setting 8, I'm unsure whether to reduce my power setting to 2 and see what effect that has What do you think? Thanks guys |
Also, I've ground the bonnet hinge box off of the front crossmember so it can go on again correctly, but it's burnt through in a couple of places
Is this still good, or should I buy a new one? They're pretty cheap, so I'll buy a new one if that's best, but I'd also like to keep all the original items where possible ![]()
Weld thru primer????? Thats only for seams that cant be primed later such as wheel wells and pinch welds at the bottom of rockers you dont want to be using that everywhere you make a weld..THAT might be part of the problem...You need to post pics so we can see what your welds are looking like with the changes your making...show us some pics of your nozzle so we can see the tip and wheres you gas set at ???? lets start at the begining ,not even a pro can weld if the machine aint right
Yes, I put weld through primer on the pieces I was struggling with I actually put a couple of nice coats on there I obviously didn't put any primer on the scrap pieces I was playing around with earlier and they were coming out really nice As mentioned earlier, I did struggle with a few practice pieces, but I think that might have been due to the box section I was using had underseal and paint inside it in some areas When I was going over these areas the weld would just hiss and not sizzle It sounded and looked like the video I posted earlier where the guy sets the feed speed too low. I wouldn't get any penetration in these areas it just blew the paint and underseal off of the reverse face I didn't think to take any pictures of my practice pieces I'll get some posted when I get back to the garage, probably towards the end of the week |
They say that "cleanliness is next to goddlyness". Weld prep is very important. I clean everything I weld with the TIG. The Mig I used to be a bit relaxed with but it does work a lot better if the surface(s) are clean.
Although it is very time consuming, it is a vital part of the welding process. |
like painting ,prep is everything 'nothing worse than running a perfect bead, hitting some crap and ruining everything..
That undercoating is melting and screwing with your weld.... |
Welding...........
Quit screwing around,this thread is way too long,either weld it yourself,or find someone to weld it for you !!!
Bob, if my learning has annoyed you in anyway I am sorry |
learning.
No,your learning has NOT annoyed me,BUT this thread has 53 replys,,time to put this thread to bed.
When grinding you need to be aware of the thickness and try to maintain it or the strength is diminished. |
That whole mess needs to come off, nice shiny bare metal in the weld zone. Get a puddle started on one side of the gap and let it melt into the base metals, more the puddle across the gap letting it fill and melt into the base metal on the other side. move slightly uphill with the puddle and work back across to the first side. Repeat till you are at the top. IF it goes wrong STOP. It wont get better by splattering more bird turds on it , it will only require you to spend more time grinding. the only place you should be spraying weld thru primer is where paint cannot be applied after welding, like a lap joint , or the inside of a box. I think you should consider finding a person that welds that will come over and spend a hour with you and get you headed in the right direction on some scrap pieces. It is nothing to weld a practice set up for hours on end, take a break, and go right back to practicing the same thing again. Repetition makes perfection. |
Easy solution, Bob. DON'T CLICK!
Make sure your ground connection is clean and even grind a spot if there is doubt. Very important as a poor ground connection will eat up some of the voltage your wire needs to see. Be the same sort of clean with the weld area also. MIG has poor penetration properties anyway, having a CLEAN/SHINEY weld area will allow the metal to puddle with lower voltage and give you a better looking and penetrating weld. I personally can't see your feed speed being too slow if you are on 8 with a power setting of 1 or 2. Seems way too high to me. Is there a chance you are working outside or somewhere there is a draft? The symptom you discribe has happened to me when a draft or wind blows the gas away from the weld or the few times I had brain fade and started the weld before turning on the bottle. Just thinking. Classes are a great idea also. One hands on demo is worth a thousand posts.
i hate to suggest it, but i wouldn't ride in anything you welded ant.
i'd hate to even be on the same road that your driving down. you really need to find someone else to weld it. you need to get better at welding before you attempt any structural welding. |
| T-400 over fill | cletusvandamme | Transmission - Rearend | 5 | 08-10-2009 02:02 AM |
| Butt welding vs Spot welding | 69ChevelleAddict | Body - Exterior | 19 | 05-04-2008 01:47 AM |
| sbc block fill | dirtracerx | Engine | 5 | 09-15-2006 05:15 AM |
| Block fill | WakBordr7387 | Engine | 8 | 01-16-2006 12:57 PM |
| Fill ' er up! | 66GMC | General Rodding Tech | 5 | 09-22-2005 01:41 PM |
