Can I get rear discs for a 61 Chrysler 300G? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2012, 11:57 AM
turbovanman's Avatar
Doing some work on a customers 300G, I am putting some front discs on from Scarebird but now customer want's rear discs too. Got a call out to them but any other options? No e-brake needed due to one being on the driveshaft, looks to be 12" drums but don't have the wheels off. Stock bolt pattern, 5x4.5" bolt patttern. TIA.
I guess I should add, any options for the MC setup using the stock brake pedal?
Simon
Old 01-09-2012, 12:10 PM
delawarebill's Avatar
chry disc
http://www.chrysler300club.com/jhstu...opar/disc.html
try this web site.. didn't read it, just did a google this came up.. maybe it'll help..
Old 01-09-2012, 12:13 PM
Thanks, I did try google and found only fronts, which you found, but need the rear. I'll check out the website and see if they did the rear.
Old 01-09-2012, 12:16 PM
Ooops sorry
thats what happens when i don't read the websites...
Old 01-09-2012, 12:26 PM
Wiki Edits: 49
Hope you have the correct puller to get those rear drums off. The drums/hubs on the tapered axle 8.75" rears are swedged together. If you don't use the puller you can damage the hubs and no one is reproducing them.
I wrote a Wiki article (HERE) which talks about how to remove these drums and replace the lug bolts without damaging the hubs. The backing plate holds the axle in the housing so a disk kit may or may not be an option. Chances are someone is making a disk kit for these but I haven't heard of any.
Good luck.
Centerline
HotRodsAndHemis.com
The most important things you learn are those things you learn AFTER you know it all. -- Chip Foose
Ford Rear Discs, revisited. DONE! Psquare75 Suspension - Brakes - Steering 39 07-18-2006 06:10 PM
Ford Rear Discs Cobbled Together Psquare75 Suspension - Brakes - Steering 34 11-21-2005 03:47 PM
79 trans am rear discs busterbuddie Suspension - Brakes - Steering 7 01-20-2005 09:58 AM
79 trans am rear discs busterbuddie Suspension - Brakes - Steering 2 01-10-2005 06:29 PM
Rear discs? SS Monte Transmission - Rearend 3 10-22-2003 08:55 PM
