Can I get some paint gun advice? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2006, 09:59 PM
Car Nut
Hi guys. I'm painting a '58 Impala and I'm painting it with Deltron DBC 9700 Black base and Concept 2021 Clear. I'm using Omni MP213 GP Sealer gray over my primer surfacer below the topcoat. Ok, I'm using a Sharpe T1 Titanium spray gun with a 1.4mm tip for the sealer and the basecoat and I'm using a Devilbiss GTI Millenium spray gun with a 1.3 mm tip for the clear.
I'm having a problem getting the sealer and the clear to lay down good. I'm having trouble adjusting the gun to where the sealer will lay down w/o running or being too dry. I over reduced the sealer a little to help it lay down but I'm having more of a dry spray problem. I'm using a 6 in. pattern 6 in. from the surface for all coats of all products.
As far as the clear goes, I'm mixing the first coat the way the directions call for and then on my next two coats, I over reduce. I'm having more orange peel than I or my boss would like. He wants me to be able to paint and it come out smooth enough to scratch a little and buff and not have any swirl marks. Some people want everything!! LOL.
I'm also wanting to know of any suggestions on getting swirl marks out of the paint because this black Impala will be a show car and the guy expects show quality. I'm sanding with 1000, 1500, to 2000 sandpaper, then buffing with a 3M superbuff double sided yellow wool pad along with Perfect it 3 compound, then to a 3M black convoluted foam pad with Perfect it 3 Trizact Machine Glaze, then to the same foam pad with Perfect it 3 final glaze. There are still some swirl marks. Is there any way to get them out and are there any good products as far as like cotton cloths for hand polishing that won't scratch the surface?
This car is gonna look dynamite when I'm done. I've got the door, trunk lid, dash and package shelf in the rear looking like glass. I would just like to get the clear and undercoats to lay down smoother. Something I forgot to mention is that I'm having problems with solvent pop. I've got the booth and the metal surfaces I'm painting around 70 to 75 degrees. I'm wainting about 15 to 20 minutes b/w coats and I'm using the DT870 reducer for base and clear. About the second coat of clear is when the clear starts forming its bubbles. Any help is much appreciated? Thanks lots!
Old 03-29-2006, 10:23 PM
I've never used the Omni sealer is it a 2K? How much flash time between base and clear? Black really holds solvent and needs extra flash time usually and most people really put it on wet which can also add to solvent trap problems. Do you really need a sealer on this job? If you want to handrub the car to remove any machine marks use the older Finesse it II, it's white and comes in a quart sized bottle and been around since the late 80's, used with a soft cloth and some elbow grease it'll remove all those swirls and gives a really nice shine. Is the clear going on with orange peel or is it looking peely because the sealer and basecoat had texture? Bob
Old 03-30-2006, 06:47 AM
Maybe you could try to start with 1200 then 1500 and finally 2000 , or if this is gonna be a car show directly start with 1500.then 2000 and finally 2500..it would take alot of time with this grid but the results would be better..
Sorry for my english and good luck.
Old 03-30-2006, 07:05 AM
Car Nut
Thanks for the replies!
Thanks for the info guys. I'm probably just not waiting long enough between the base and clear coats and thats probably why I'm getting the solvent pop. I usually wait about 20 minutes between the last coat of base and the first coat of clear. I probably need to wait longer.
I'm kind of new to the painting scene but this Impala is my second complete paint job. So far I'm really happy with how everything is turning out, besides the fact that it's taking forever and the customer doesn't understand why. People will never have any idea of what it takes to make a 40, 50, or 60 year old car look like show car quality. It's more work than just scratching the surface, painting, and away you go.
I really appreciate the replies and I think this forum is awesome as well as the people in it. I've read quite a few postings and they are all very interesting. A lot of the people on here really know what they are talking about. Maybe if I can get some pictures on here of the parts I've painted, you guys can check it out. This Impala is a car you don't see very often where I'm at. Thanks and God Bless.
Old 03-30-2006, 08:05 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Might either swap guns for each procedure or try a 1.4 in the DeVilebliss.
Could be the 1.3 is not large enough for the clear and you either have too little or too much clear shooting out it.
I know it would be more work,but try a wet sand of the sealer with a wet gray scotch pad. That will slick it out really nice if you have some grain in it.
Old 05-07-2006, 10:49 PM
Dewcat's Avatar
I just bought a Devilbiss gfg 670 gravity Plus and its great, but the 1.3 wasnt shooting base very good so I went to the 1.4 and its great. I have learned to be patient to soon on next coat will be sand time again like they said solvents get trapped if you try to build rome in a day trust me I learned the hard way.
This is interesting. Temporary peel off paint. kenseth17 Body - Exterior 5 08-11-2005 10:41 PM
Is This Paint Gun OK? Kampr Body - Exterior 8 07-17-2005 09:04 AM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 09:49 PM
harbor freight hvlp gun jn0w Introduce Yourself 2 06-15-2004 04:08 PM
1st painting nova33 Body - Exterior 19 06-16-2003 11:05 AM
