Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - can i install a 2 step without a transbrake
Old 12-01-2012, 07:41 AM
sparkchaser sparkchaser is offline
I have a button on my brake pedal that will turn on the two step. I haven't been able to get it dialed in to the optimum RPM I want, because none of the footbrake events I run in will allow any electronics. I made a large heavy duty brake pedal so I could apply the brakes with or without stepping on the switch. It would be nice to be able to use a 2 step while powerbraking, because you could get your launch RPM exactly where you want it. Once you stage, there's not much time too look at the tach, set your RPM, and then watch the tree.
