-   -   can i install a 2 step without a transbrake (http://www.hotrodders.com/forum/can-i-install-2-step-without-transbrake-226684.html)
menoaz 11-30-2012 04:24 PM
I cant find a thread that can answer this. I want to install a msd 2 or 3 step and use a step for launch at 3000. How would i do this withou a tranny break?
sparkchaser 11-30-2012 08:13 PM
transbrakes and/or line locks are wired in parallel with the switched red power wire on a 2 step. You don't have to use them, just connect your push button to the red power wire and you get rpm limiting.
menoaz 12-01-2012 02:07 AM
Is there a better 2 step than another for a nontransbrake application? Ive seen something called a soft limter not sure what that is. I take it i release the button and the foot brake at the same time. Is there gonna b a delay?
sparkchaser 12-01-2012 06:41 AM
1 Attachment(s)
I have a button on my brake pedal that will turn on the two step. I haven't been able to get it dialed in to the optimum RPM I want, because none of the footbrake events I run in will allow any electronics. I made a large heavy duty brake pedal so I could apply the brakes with or without stepping on the switch. It would be nice to be able to use a 2 step while powerbraking, because you could get your launch RPM exactly where you want it. Once you stage, there's not much time too look at the tach, set your RPM, and then watch the tree.
menoaz 12-01-2012 09:02 AM
Thanks spark for the pic. I see the light now.
