can i install a 2 step without a transbrake - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2012, 05:24 PM
menoaz's Avatar
I cant find a thread that can answer this. I want to install a msd 2 or 3 step and use a step for launch at 3000. How would i do this withou a tranny break?
Old 11-30-2012, 09:13 PM
transbrakes and/or line locks are wired in parallel with the switched red power wire on a 2 step. You don't have to use them, just connect your push button to the red power wire and you get rpm limiting.
Old 12-01-2012, 03:07 AM
menoaz's Avatar
Is there a better 2 step than another for a nontransbrake application? Ive seen something called a soft limter not sure what that is. I take it i release the button and the foot brake at the same time. Is there gonna b a delay?
Old 12-01-2012, 07:41 AM
I have a button on my brake pedal that will turn on the two step. I haven't been able to get it dialed in to the optimum RPM I want, because none of the footbrake events I run in will allow any electronics. I made a large heavy duty brake pedal so I could apply the brakes with or without stepping on the switch. It would be nice to be able to use a 2 step while powerbraking, because you could get your launch RPM exactly where you want it. Once you stage, there's not much time too look at the tach, set your RPM, and then watch the tree.
Old 12-01-2012, 10:02 AM
menoaz's Avatar
Thanks spark for the pic. I see the light now.
Good GM Transmission Link for step-by-step instructions d&c repairs it all Transmission - Rearend 0 09-30-2008 04:12 PM
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 08:39 AM
illustrated step-by-step wing window replacement bullheimer Body - Exterior 0 04-08-2008 12:13 AM
I need a step by step idiots guide. lol... gto nut 00 Transmission - Rearend 6 03-29-2006 11:16 AM
Rebuilding my first Q-jet carb and need step by step. MopaRV Engine 8 12-31-2002 04:41 PM
